> Rear main seal replacement, any how-to's on how to remove a transmission?
post Aug 14, 2007 - 1:56 AM
6strngs
Joined May 12, '06
From Wilmington, NC
so basically I've got a pretty bad oil leak that I'm 90% sure is from the rear main seal. so I'm going to be replacing that sometime, like this weekend maybe. I was wondering if anybody could give me some general directions on how to remove the (manual) transmission as I've never done it before. also, are there any other seals or gaskets I need to replace while I do this, or are there any things that are recommended I do while this is out?
- 6strngs   Rear main seal replacement   Aug 14, 2007 - 1:56 AM
- - soulshadow   Take out the motor and tranny together. Its much e...   Aug 14, 2007 - 10:40 PM
- - 6strngs   I don't have the tools to remove the motor, an...   Aug 15, 2007 - 12:28 AM
- - 6strngs   come on, nobody has anything to say? right now, I...   Aug 17, 2007 - 10:09 AM
- - 6strngs   can anybody tell me how to take the driver's s...   Aug 18, 2007 - 11:38 PM
- - jc47   Are you completely sure that the rear seal is leak...   Aug 19, 2007 - 11:32 AM
- - lagos   QUOTE(6strngs @ Aug 19, 2007 - 12:38...   Aug 19, 2007 - 11:47 AM
- - WannabeGT4   If you don't have a CV shaft puller I found th...   Aug 19, 2007 - 12:41 PM
- - 6strngs   well, I got it out. I went out and searched for a ...   Aug 19, 2007 - 3:31 PM
- - WannabeGT4   There are two U shaped clips holding the cables in...   Aug 19, 2007 - 5:01 PM
|- - 6strngs   QUOTE(WannabeGT4 @ Aug 19, 2007 - 3...   Aug 19, 2007 - 5:07 PM
- - WannabeGT4   Hit 'em with a hammer, pry on them with a scre...   Aug 19, 2007 - 5:13 PM
- - 6strngs   yeah, I got them. I actually did follow your advis...   Aug 19, 2007 - 9:16 PM
|- - CaliJeff   QUOTE(6strngs @ Aug 19, 2007 - 7:16 ...   Aug 19, 2007 - 9:22 PM
- - soulshadow   so.......what are you supporting the motor with wh...   Aug 21, 2007 - 11:13 PM
- - 6strngs   I've got one jack under the motor, one transmi...   Aug 22, 2007 - 2:30 AM
- - 6strngs   that's weight reduction... right? and in cas...   Aug 26, 2007 - 11:52 AM
- - 6strngs   three full weeks? have I really been doing this 3 ...   Sep 3, 2007 - 2:15 AM
- - lubu   good work bud, good to see that car is up and runn...   Sep 3, 2007 - 2:30 PM
- - 6strngs   yeah, I could only lift the transmission high enou...   Sep 3, 2007 - 11:45 PM
- - soulshadow   Awesome JOB! Good Work!   Sep 12, 2007 - 11:46 AM
Lo-Fi Version Time is now: August 2nd, 2026 - 3:25 PM
