> FS: "3SGTE Swap" Competition Clutches
post Aug 14, 2007 - 10:15 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Custom clutch using 3SGTE clutch plate and pressure plate with S-series hub to use the stock S54 transmission from the 5SFE. Stage 2, 500 mile break-in, holds 300 ft/lbs. Good for stock or mildly modded 3SGTEs. Retail $425, special for 6GC members: $362.
drtweak@phoenixtuning.com
I can also get any other clutches that you may need, so just let me know!
-Doc
Click here to see my swaps
post Aug 28, 2007 - 10:50 AM
Dr_Tweak
Joined Mar 31, '04
I also have stage 3 and stage 4 6-puck and 4-puck discs available.
-Doc
post Oct 2, 2007 - 1:16 PM
flying-corolla
Joined May 13, '06
From Superior, WI
would you be willing to just sell the clutch disc?
post Oct 3, 2007 - 1:59 PM
Dr_Tweak
Joined Mar 31, '04
I don't think I can break it up like that.
-Doc
post Oct 10, 2007 - 9:27 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Price for the Stage 3 - Street/Strip Series 2300 Clutch Kit? Do they have a lightweight flywheel available for the swap under 12lbs? If so what kinda price could I get on both together?
post Oct 11, 2007 - 6:01 AM
Dr_Tweak
Joined Mar 31, '04
Retail on that clutch is $525, I can get it for you for $469. You may want to consider the 6-puck 1620 clutch which is actually a little cheaper, $425 retail and $379 is what I can get it down to. There are two flywheels, an 11lb and a 9lb, the 11lb is retail $349 ($309 for you) and the 9lb is retail $369 ($329 your price). Shipping for everything together is only like, $25.
-Doc
Lo-Fi Version Time is now: September 15th, 2026 - 12:26 PM
