> Advanced Timing: Good or Bad?
post Aug 17, 2007 - 12:42 AM
xs94st
Joined Aug 11, '07
From Corona, CA
Hey guys I got an NA ST 7afe n i was just wondring about advancing my timing. I know that you can gain some hp in the wheels, but is it good for the car? Also, how exactly can u advance your timing? Can a local shop do it for you? Does fuel octane have a minimum for maximum power? Thanks in advance! haha
Pandelica 2.0 in progress.
post Aug 17, 2007 - 12:45 AM
Redline08
Joined Feb 23, '07
From Albany, NY
yea was thinking about doing this too, i know that timing lights are ~$50 and its not hard too do yourself, but thats all i know...
post Aug 17, 2007 - 6:56 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
the how-to on the internet for the 5th gen 5sfe works just fine to use for the 7afe, yes you need to bump up your octane.
post Aug 17, 2007 - 10:12 AM
6strngs
Joined May 12, '06
From Wilmington, NC
no need to have a shop do it. you just need a $50 timing light (or borrow a friend's), and a 12mm socket with wratchet. if you don't have that, you could probably do it with a 12mm wrench. you just need to loosen one bolt, spin the distributor, and tighten the bolt back up.
post Aug 17, 2007 - 10:41 AM
xs94st
Joined Aug 11, '07
From Corona, CA
is there any long term effects that may damage your engine?
post Aug 17, 2007 - 12:33 PM
Bitter
Joined Mar 11, '06
QUOTE(6strngs @ Aug 17, 2007 - 10:12 AM) [snapback]588672[/snapback]
2 bolts, one is a REAL pain to get to.
QUOTE(xs94st @ Aug 17, 2007 - 10:41 AM) [snapback]588678[/snapback]
more heat and pressure, increased chance of knock, probably just a little more wear and tear than you'd normally get. i've been advanced for about 7k miles now without really any ill effects to speak of.
post Aug 17, 2007 - 7:07 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Bitter @ Aug 17, 2007 - 10:33 AM) [snapback]588699[/snapback]
ok, I guess the 7a has two bolts. 5s has one.
as long as you use a higher octane gas, and don't advance TOO far, you won't hurt anything.
post Aug 17, 2007 - 7:10 PM
Bitter
Joined Mar 11, '06
bingo, with an intake or just a derestricted airbox 5deg of timing really added some smooth power to the engine. all the way from off idle and it faded just around 5000 rpm. the header killed the fade and moved the power to the midrange.
post Aug 17, 2007 - 11:25 PM
Redline08
Joined Feb 23, '07
From Albany, NY
any noticable power gain on a 15 degree advance?
and what octane do u run on with 15 degrees?
post Aug 18, 2007 - 12:19 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Redline08 @ Aug 17, 2007 - 9:25 PM) [snapback]588817[/snapback]
yeah, I noticed a difference in accelleration. I ran it on 91 octane no problem, then I advanced to 18 on 91 octane still with no problems, then I went back to 15 but used 89 octane, again with no problems.
post Aug 18, 2007 - 12:24 AM
Redline08
Joined Feb 23, '07
From Albany, NY
nice, thanks alot man!
Lo-Fi Version Time is now: June 12th, 2026 - 12:53 PM
