> wtb: 3rd gen 3s OILPAN
post Aug 18, 2007 - 1:47 AM
urbandork
Joined Jul 16, '04
From Los Angeles
something bad happen with my cv joint.... and now i need a new oil pan.. the part that i particularly need is that aluminum adapter plate that relocates the oil filter to the bottom where the pan is.
i may just weld it up but i wanted to see if anyone of you had an extra one.
Replies (1 - 4)
post Aug 18, 2007 - 3:28 AM
celicaracer18
Joined May 23, '04
From Meridian, MS
i may have a forth gen, but its in MS where as i'm in Fl right now so it would take at least a week to get it here and make sure its the same, from what i can remember thay are identacal, in fact i amy be using the forth gen have the 3rd sitting back home, can't remember which i used
post Aug 18, 2007 - 3:54 AM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(celicaracer18 @ Aug 18, 2007 - 8:28 AM) [snapback]588858[/snapback]
to bad...
i need this this week.... any chance u can get some one to take pix???
oh and how much with shipping cus i want to make sure its not cheaper jsut welding it up
This post has been edited by urbandork: Aug 18, 2007 - 3:55 AM
post Aug 19, 2007 - 11:05 AM
celicaracer18
Joined May 23, '04
From Meridian, MS
do you need the lower oil pan or the upper
my lower is dented i think, but the upper (the aluminum one) is fine, i'll see if i can get my dad to take a pic and get it to me monday
not sure how much, depends on what its worth i guess,
and it will might be cheaper to weld it but i'm not sure that would be safe
be sure and get a good welder
let me know how much this part should cost, do you think you could find out a price from toyota for the second gen i'll let it go for much less of coarse
i was thinking about $50 but that might be two much, just let me know
post Aug 20, 2007 - 2:13 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(celicaracer18 @ Aug 19, 2007 - 4:05 PM) [snapback]589109[/snapback]
im pretty sure all i need is the aluminum one but ill have to check. pix to verify the item would be great.
Lo-Fi Version Time is now: July 10th, 2026 - 8:55 AM
