Aug 20, 2007 - 12:58 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
well the axle autozone gave me was obviously too short...
when i took a corner the cv joint broke and the result was a hole in my oil pan... hopefully only that and not the 3rd gen 3sgte block i have alkfjldjf..... it was horrible... my car sat parked with oil spilling out from under it. The trans is in the same spot and has not moved after the swap... i know this because the trans/motor mounts (front rear and driver side mount)are still the 5sfe mounts and thus the trans is mounted in the same place it was when it was mated to the 5s.... (yes im still using the s54 with an helica lsd unit from a c56/52 [mrs] with a hybrid clutch from spec) when on the lift with the suspension uncompressed the cv joint is obviously too short. the bearings are out of the cylinder thing where they are suppose to still be in. n e way.... i think autozone gave me the wrong axle... is it a posiblity that they gave me a camry or 5th gen axle that was too short?? im going to get a real axle for my car and compare the two on mon but thought id get some input from you guys thanks This post has been edited by urbandork: Aug 21, 2007 - 4:26 PM |
Aug 20, 2007 - 1:03 AM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
Very possible. As I needed new lug nuts from them. There computer quoted that I needed m12 .25 when we actually use m12 .50. So I would imagine someone put the wrong numbers in and in turn you were given the wrong axle.
Aug 20, 2007 - 1:41 AM
QUOTE(Harold_Fastwaker @ Aug 20, 2007 - 6:03 AM) [snapback]589295[/snapback] Very possible. As I needed new lug nuts from them. There computer quoted that I needed m12 .25 when we actually use m12 .50. So I would imagine someone put the wrong numbers in and in turn you were given the wrong axle. i dont see how lug nuts have n e thing to do with an axle... or r u talking about the nut that holds the axle onto the hub |
Aug 20, 2007 - 11:18 AM
welcome to autozone! they sold me about 5 axles in a row that were bad. some were too long, too short, broken in the box, broken after 5min of driving, etc...
try napa or car quest. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 20, 2007 - 12:07 PM
![]() Enthusiast ![]() Joined Nov 20, '03 From Derry, NH Currently Offline Reputation: 2 (100%) |
QUOTE(lagos @ Aug 20, 2007 - 4:18 PM) [snapback]589383[/snapback] welcome to autozone! they sold me about 5 axles in a row that were bad. some were too long, too short, broken in the box, broken after 5min of driving, etc... try napa or car quest. X2 i have never had anyluck with autozone parts -------------------- |
Aug 20, 2007 - 6:48 PM
Enthusiast ![]() ![]() Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) |
X3
I gave up on Autozone and Pepboys x 2years now. Just got tired of going back and forth replacing parts I got from them. I now just cough it up and get OEM as much as possible. I think NAPA by far appears to have better products - at least regarding callipers, that is. -------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
Aug 20, 2007 - 11:29 PM
QUOTE(urbandork @ Aug 20, 2007 - 2:41 AM) [snapback]589309[/snapback] QUOTE(Harold_Fastwaker @ Aug 20, 2007 - 6:03 AM) [snapback]589295[/snapback] Very possible. As I needed new lug nuts from them. There computer quoted that I needed m12 .25 when we actually use m12 .50. So I would imagine someone put the wrong numbers in and in turn you were given the wrong axle. i dont see how lug nuts have n e thing to do with an axle... or r u talking about the nut that holds the axle onto the hub I dont see what was so hard about understanding my statement. I explained that Autozone screws up all the time and it would make sense you would receive and improper part. -------------------- |
Aug 21, 2007 - 4:28 PM
QUOTE(Harold_Fastwaker @ Aug 21, 2007 - 4:29 AM) [snapback]589588[/snapback] QUOTE(urbandork @ Aug 20, 2007 - 2:41 AM) [snapback]589309[/snapback] QUOTE(Harold_Fastwaker @ Aug 20, 2007 - 6:03 AM) [snapback]589295[/snapback] Very possible. As I needed new lug nuts from them. There computer quoted that I needed m12 .25 when we actually use m12 .50. So I would imagine someone put the wrong numbers in and in turn you were given the wrong axle. i dont see how lug nuts have n e thing to do with an axle... or r u talking about the nut that holds the axle onto the hub I dont see what was so hard about understanding my statement. I explained that Autozone screws up all the time and it would make sense you would receive and improper part. oh i see what you were saying. n e way i compared the autozone axle to an oem one and it indeed is too short. thus the reason why it broke and make a hole in my oil pan..... ..... i plan on returning it and also calling autozone corporate to see if i can get my money back from for my troubles and for all the tranny fluid i had to buy. |
Aug 21, 2007 - 4:36 PM
HAHA good luck with that plan. they will refund the axle tho. just make sure you still have your core.
Aug 21, 2007 - 7:18 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
QUOTE welcome to autozone! they sold me about 5 axles in a row that were bad. some were too long, too short, broken in the box, broken after 5min of driving, etc... try napa or car quest. yea. they dont know wtf to order. they jus regular people that look at stuff on computers sometimes, not knowing anything about autos. gave me the wrong axles and made me drive 110 miles round trip to return em. lame. dont go autozone. -------------------- ![]() Pandelica 2.0 in progress. |
Aug 21, 2007 - 11:25 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
You can actually sue them for providing you with dangerous and unsafe parts that did not match your specified vechile, but intended for it.
This falls under the category of (Bait and Switch) = "These will meet or EVEN exceed OEM specs." Basically they have to pay for any damages, harm, MENTAL damages (MEEEENNNTTTTAAAALLLLLL), and wat-so-ever. Then again it only works if: 1.) A pro installed it with proof or a good proof that ur a pro. 2.) You still have the receipt 3.) You take them to court and sue. |
| Lo-Fi Version | Time is now: September 11th, 2026 - 1:20 PM |
