Aug 27, 2007 - 7:14 AM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) |
I have a 3s swap and was wondering if i needed the AFM for the motor to run? The AFM and the plug that goes into the AFM doesn't match up.
team_omega AFM Aug 27, 2007 - 7:14 AM
WannabeGT4 If it's a second gen swap you will.
You proba... Aug 27, 2007 - 12:00 PM
devilsden97 your afm could be from a 4agZe Aug 27, 2007 - 12:41 PM
toyotacrazy QUOTE(devilsden97 @ Aug 27, 2007 - 12... Aug 27, 2007 - 7:37 PM
team_omega here the pix of the AFM plug, the both slot on the... Aug 30, 2007 - 10:12 AM
lagos thats the plug for your igniter. Aug 30, 2007 - 10:58 AM
Defgeph I dont think thats an RC wiring harness. My colors... Aug 30, 2007 - 1:51 PM
WannabeGT4 That's an igniter plug... It can be modified t... Aug 30, 2007 - 2:38 PM
team_omega Ok i have two plugs that looks like this but this ... Sep 1, 2007 - 9:36 PM
WannabeGT4 Post your part numbers!
What are the wire col... Sep 1, 2007 - 9:40 PM
team_omega The AFM part number 22250-74250
The ECU part numb... Sep 1, 2007 - 10:33 PM
WannabeGT4 Do not run ECU P/N 89661-2B280 with AFM P/N 22250-... Sep 1, 2007 - 10:55 PM
team_omega how could i bypass this without using it the AFM? ... Sep 11, 2007 - 10:47 PM
WannabeGT4 You could buy buy a stand alone or the MAP ECU. Sep 12, 2007 - 7:30 AM
team_omega im not too familiar with piggybacks. will this pl... Sep 12, 2007 - 10:29 AM
WannabeGT4 The MAPECU needs to be hard wired but it comes wit... Sep 12, 2007 - 11:55 AM
team_omega QUOTE(WannabeGT4 @ Sep 12, 2007 - 11... Sep 12, 2007 - 10:55 PM
lagos its in your engine bay. Sep 12, 2007 - 11:24 PM
team_omega QUOTE(lagos @ Sep 12, 2007 - 11:24 P... Sep 12, 2007 - 11:42 PM
lagos i meant the connector for the afm. the pic of the... Sep 13, 2007 - 12:14 AM
team_omega QUOTE(lagos @ Sep 13, 2007 - 12:14 A... Sep 13, 2007 - 7:04 AM
WannabeGT4 Post a pic of the other plug and wire colors. I ca... Sep 13, 2007 - 9:27 AM
lagos QUOTE(team_omega @ Sep 13, 2007 - 8... Sep 13, 2007 - 12:24 PM
team_omega QUOTE(lagos @ Sep 13, 2007 - 12:24 P... Sep 13, 2007 - 10:45 PM
team_omega here some pix i took and i need to know where that... Sep 30, 2007 - 5:24 PM
WannabeGT4 Plug one is for the AFM. If it doesn't fit bus... Sep 30, 2007 - 6:47 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 28th, 2026 - 9:32 AM |
