> i need help with my st
post Aug 28, 2007 - 4:03 PM
slow94st
Joined Oct 8, '06
From Jersey sHore PA
I was wondering if somebody could tell me were the ground wires are located so i can clean them. The reason 4 this is because my car wont start and i just got my starter rebuilt and i was told to clean them.
3sgte next year i hope
Replies (1 - 7)
post Aug 28, 2007 - 8:10 PM
GrimReaper
Joined Jul 27, '07
From Québec, Canada
Easy, follow your negative cable right from the battery, it should be bolted to the chassis (body) and to the engine block. Tighten all bolts if necessary, and also clean your engine block or tranny housing where the starter is mount. The ground of the starter is the engine block itself. Also clean all the positive connections that come to the starter. Try that and tell me how it works wink.gif
post Aug 29, 2007 - 5:26 PM
slow94st
Joined Oct 8, '06
i was wandering if you or anybody knew were they are located sence the previous owner relocated the battery to the trunk and i cant trace the neg wire
post Aug 29, 2007 - 5:52 PM
GrimReaper
Joined Jul 27, '07
From Québec, Canada
Sorry to tell you that, but you'll have to trace the ground wire. No way to be shure that you have good grounds other way kindasad.gif Or, try to get a 8 gauge wire and set a new ground for your engine block, running it from the negative, under your Celica. But if it's not your trouble, you'll waste your money mad.gif
post Aug 29, 2007 - 7:40 PM
slow94st
Joined Oct 8, '06
ok so i found the ground wire, it was bolted to the trunk floor, so i cleaned it and tried to start it and got nowere, so i took my truck to the front and hooked it to the positive cable and hooked the neg to the block and still got nothing, i push in the clutch and turn the key and it makes like a click noise coming from like the front center consoul
post Aug 29, 2007 - 7:45 PM
GrimReaper
Joined Jul 27, '07
From Québec, Canada
Bad positive connections, bad relays, bad clutch killswitch, bad starting switch, your problem could be anything like this. Do you have an anti-thief system of some kind?
post Aug 29, 2007 - 7:53 PM
slow94st
Joined Oct 8, '06
no anti-theif system
This post has been edited by slow94st: Aug 29, 2007 - 7:53 PM
post Aug 29, 2007 - 8:06 PM
GrimReaper
Joined Jul 27, '07
From Québec, Canada
Sorry kindasad.gif your question is too large, to be answered just like that. Need to be fixed by a professional kindasad.gif Too many possible cause rolleyes.gif
Lo-Fi Version Time is now: June 12th, 2026 - 12:15 AM
