Aug 29, 2007 - 6:24 PM
Enthusiast ![]() Joined Aug 19, '07 From new providence P.A. Currently Offline Reputation: 2 (100%) |
can some one explaine why i need this?
http://i179.photobucket.com/albums/w310/di...95/100_0308.jpg http://i179.photobucket.com/albums/w310/di...95/100_0307.jpg http://i179.photobucket.com/albums/w310/di...95/100_0306.jpg This post has been edited by toyocelgt95: Aug 29, 2007 - 6:25 PM -------------------- ![]() |
Aug 29, 2007 - 6:50 PM
Enthusiast ![]() ![]() Joined Apr 11, '06 From Tasmania Currently Offline Reputation: 0 (0%) |
That is for your Cruise Control that is the motor that holds your throttle open so you dont need your foot on the peddal.
now you got to see if you have the buttons on you stearing wheel ![]() -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Aug 29, 2007 - 6:56 PM
yea, i have the controll switch on the steering wheel. but the battery is in the back of the car becouse thats mounted were the batery goes. were are they soposed to be located ? thanks
Aug 29, 2007 - 7:11 PM
their is ment to be a bracket that is a
"7_" shape that bolts under the battery and moves up the side of the battery and then flat. I cant find a pic on the net at the moment but I got one at home I can take a pic and post it. It's looking like you Cruise Control has been put in after or somthing. -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Aug 29, 2007 - 11:20 PM
ok. thanks. is it hard to just remove it couse i never plan on using it. and different cables or anything that i would need? thanks
| Lo-Fi Version | Time is now: June 12th, 2026 - 7:54 PM |
