Aug 30, 2007 - 8:37 PM
Enthusiast ![]() Joined Mar 17, '05 From Northridge, CA Currently Offline Reputation: 0 (0%) |
My car was leaking a bunch of fluid when I got it back from the transmission shop to have my clutch installed. At first I thought it was engine oil, but after figured out it wasn't that, I just thought it was some extra oil or something (really didn't know).
Now I think it might have been transmission oil. My transmission is making some whining sounds and shifts are getting harder. Do they normally drain transmission fluid when replacing a clutch? I didn't think that was necessary. Should I just take it in for a transmission fluid flush? It jsut started like 2 days ago, but when I go to put it in 5th, the shifter is really stiff and when I force it, it sorta catches, but as soon as I let go of the clutch, it starts to grab but then the shifter moves back to neutral. I was able to get it to catch a few times, but it whines like a mofo.... How can I check the fluid myself? What else could it be? Please help! |
Aug 30, 2007 - 8:45 PM
Also, its pretty tough to get it into Reverse. But its been like that for over a year now.
Aug 30, 2007 - 9:17 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
Also check your clutch pedal freeplay etc. if your pedal needs adjustment you may not be depressing the clutch all the way when pushing in the pedal. I had this problem on my car. After adjusting the pedal the clutch disengaged completly and the shifter wasn't stiff anymore! Also check your tranny fluid level, yes when you do a clutch you drain the fluid, because you have to take out the axles, unless they can do it without removing the axles..?
Aug 30, 2007 - 9:32 PM
Enthusiast ![]() ![]() Joined Jul 29, '07 From Quebec, Canada Currently Offline Reputation: 0 (0%) |
no, to access to the clutch, you have to remove the axles, and the 5sfe tranny, this one especially,
lose all tranny fluid when you remove the axles. this is a bitch, but it is very tough, i can confirm it to you, my 3sgte RC is not able to push her out;) |
Sep 4, 2007 - 3:02 PM
So after taking a look at it myself, I found that I was missing the Fill Plug on the transmission!!!!! It must have came off or the ****ers at the tranny shop didn't put it back on. I was riding around without gear oil for about 3 weeks!
I wasn't able to find another plug at autozone/pep boys/kragen so I improvised and used a wine bottle cork! But basically after putting 2.5L of Syncromesh oil in and corking it, the car has been running like a dream since. Lesson learned, if you see oil, bitch at the tranny shop. I'll be raising hell later with them when I actually get a chance to take it in. |
| Lo-Fi Version | Time is now: May 17th, 2026 - 1:09 PM |
