> What am I missing??
post Sep 1, 2007 - 9:57 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
From Spring Valley, NY
sup guys....i need help...i installed KYB GR-2 shocks in the front with Eibach Pro-Kit...when i installed the front the springs didn't line up with the strut mount and when i turn the wheel i hear the clunking sound....
am I missing something?? i previously had KONI with Ground Control...threw out all the stuff from the previous OEM strut assembly...what goes after the spring?? is there something between the spring and the strut mount so the wheel wont clunk??
ANY HELP/ADVICE WOULD BE APRECIATED
THANX
This post has been edited by Ve1Ls1dEvolutioN: Sep 1, 2007 - 9:58 PM
post Sep 3, 2007 - 12:34 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
post Sep 3, 2007 - 12:44 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
did you put a top mount on? did you grease the bearings?
post Sep 3, 2007 - 1:03 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
yeah, lots of grease is needed.
and you did put your bumpstops back in, right?
**** Photobucket
post Sep 5, 2007 - 8:29 AM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
QUOTE(95CelicaST @ Sep 3, 2007 - 11:03 AM) [snapback]593004[/snapback]
yeah i grease the bearings...and i put on brand new KYB strut boot/bump stop
post Sep 5, 2007 - 8:52 AM
LewFX
Joined Jan 28, '05
did you put that rubber lining over the spring before it goes on the top
post Sep 5, 2007 - 11:07 AM
eggman40
Joined Aug 17, '04
From California
QUOTE(LewFX @ Sep 5, 2007 - 6:52 AM) [snapback]593558[/snapback]
x2 also did you put the bump stops back on to the shock as well???? you could cut the bump stops a little to aid in lowering.
This post has been edited by eggman40: Sep 5, 2007 - 11:08 AM
post Sep 5, 2007 - 6:17 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
didn't have a rubber lining...must have thew them out when i put koni's on 3 years ago...SO THERE IS A RUBBER ON TOP OF THE SPRING?? i'm gonna get a strut assembly from a junkyard and just take that part out...
post Sep 5, 2007 - 6:32 PM
LewFX
Joined Jan 28, '05
the rubber stops the spring from binding on the top mount
post Sep 5, 2007 - 8:55 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
yeah i guess thats what i'm missing...cuz it grinds really bad when i turn the wheel and the car is not even moving...
post Sep 5, 2007 - 10:24 PM
97lestyousay
Joined Jul 7, '03
NVM
This post has been edited by 97lestyousay: Sep 5, 2007 - 10:26 PM
JDM guy made me do it.
Lo-Fi Version Time is now: August 4th, 2026 - 1:10 PM
