> Recommended Air Pressure?, Nankang NS-II 215/35/18
post Sep 2, 2007 - 1:14 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
Tried searching the manufacturer's site and google with no luck. I found tirerack has an article on correct inflation but I'd rather go by an official number rather than looking at it. I'm thinking 32psi, but I dunno. Please let me know what's the correct inflation pressure on these tires.
post Sep 3, 2007 - 2:52 AM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
on my set i think it says 45 psi right on it
i know the number is on there just gotta look for it.
-Brian
post Sep 3, 2007 - 8:11 AM
cyb593
Joined Feb 22, '04
From USA
to get full use out of tires use what is put on the tire
post Sep 3, 2007 - 9:15 AM
i run 35~40 psi in mine
This post has been edited by playr158: Sep 3, 2007 - 9:15 AM
post Sep 3, 2007 - 7:46 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
well the tire says max 44psi. id rather not max em out.
post Sep 3, 2007 - 11:48 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
i run 225 35x18 and i keep mine around 38-40 as best as i can, have toyo t1r's with about 19-20k on them and still about 6.5-7 of tread left via depth gauge
i also hear its a good idea to keep the pressures equal across the car
like run 38 & 38 for the fronts, and for longer trips, 45 & 45 in the back for better millage, warm temp pressure that is. but its not goo to have the fronts be like 28 on the drivers and 35 of the passengers.
post Sep 5, 2007 - 7:49 PM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
Go for around 40 psi if it says 45 or 44.
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
Lo-Fi Version Time is now: August 4th, 2026 - 11:23 AM
