Sep 8, 2007 - 12:14 PM
Im mistaken maybe, but has anybody used this on the 5sfe, is it possible. what is the advantage
Sep 8, 2007 - 12:26 PM
QUOTE(njccmd2002 @ Sep 8, 2007 - 1:14 PM) [snapback]594417[/snapback] Im mistaken maybe, but has anybody used this on the 5sfe, is it possible. what is the advantage yes. on the 5sfe, it bolts right up, the reason it gets used is because it already has a turbo oil return, so when you turbo, you dont have to drill at tap your pan for a fitting. it holds the same amount of oil as the 5s pan, so there is no "advantage" to using it, other than for a turbo setup. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: March 23rd, 2026 - 11:35 AM |
