Sep 9, 2007 - 11:11 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
help me out guys heres some referance pics
-------------------- ![]() BOOST GETS YOU LAID!!!! |
Sep 9, 2007 - 11:44 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
wtf are the 2nd pics for,u cant even see teh piping..
-------------------- BANNED. for life, you moron.
Sep 10, 2007 - 8:45 AM
![]() Enthusiast ![]() Joined Jun 27, '07 From GREECE Currently Offline Reputation: 0 (0%) |
I believe chrome is better....
Sep 10, 2007 - 11:29 AM
QUOTE(CelicaST_CALI @ Sep 10, 2007 - 12:44 AM) [snapback]594794[/snapback] wtf are the 2nd pics for,u cant even see teh piping.. if u look under the turn signals u can see the black piping -------------------- ![]() BOOST GETS YOU LAID!!!! |
Sep 10, 2007 - 12:09 PM
stick with black piping.
Clock your turbo so that the outlet is pointing down, this will help you clean up your engine bay and shorten the piping. or try and clean up the amount of wires/tubes ect running around the bay if you are looking for a way to "clean up" under the hood. it just looks really busy |
Sep 10, 2007 - 1:24 PM
Enthusiast ![]() ![]() Joined Jun 26, '07 From Greece Currently Offline Reputation: 2 (100%) |
I agree stick with black piping!
-------------------- Face your fears, Live your dreams!!!
Sep 10, 2007 - 2:20 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) |
black
Sep 10, 2007 - 2:58 PM
Enthusiast ![]() ![]() ![]() Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) |
and paint/get a black intercooler!
then you can sneak up on unsuspecting dragsters and poof! That aint no radiator that there's an intercooler! -------------------- |
Sep 13, 2007 - 12:09 AM
bump
Sep 13, 2007 - 12:16 AM
Enthusiast ![]() Joined Apr 28, '07 From Venezuela Currently Offline Reputation: 0 (0%) |
black pipes look nice!.... But i preffer chrome, looks more shining and decorative xD
Sep 14, 2007 - 9:13 AM
QUOTE(playr158 @ Sep 10, 2007 - 1:09 PM) [snapback]594890[/snapback] Clock your turbo so that the outlet is pointing down, this will help you clean up your engine bay and shorten the piping. ive been thinkn about that do you think it will help with heat too? -------------------- ![]() BOOST GETS YOU LAID!!!! |
Sep 15, 2007 - 1:00 AM
Enthusiast ![]() Joined Jan 14, '06 From New York Currently Offline Reputation: 0 (0%) |
Yeah, black is preferable for the purpose of disguise.
QUOTE(jesterwr217 @ Sep 9, 2007 - 11:11 PM) [snapback]594779[/snapback] help me out guys heres some referance pics ![]() ![]() ![]() ![]() -------------------- I drive a Celica. Anything "less" is just a car! |
Sep 19, 2007 - 8:26 AM
wanted about 15 more votes to make my decision
Sep 19, 2007 - 8:42 AM
QUOTE(jesterwr217 @ Sep 14, 2007 - 10:13 AM) [snapback]595975[/snapback] QUOTE(playr158 @ Sep 10, 2007 - 1:09 PM) [snapback]594890[/snapback] Clock your turbo so that the outlet is pointing down, this will help you clean up your engine bay and shorten the piping. ive been thinkn about that do you think it will help with heat too? the only way it will help with heat is the fact that right now your pipe runs over your manifold. afterwards it will not, this should help the charge stay cooler, and shorter pipe better response, and cleaner look. |
Sep 23, 2007 - 12:17 PM
playr i clocked the turbo and rerouted the piping and now the boost builds reaaaally slow and only peaks at 5 lbs now any ideas as to whats goin on?
Sep 23, 2007 - 12:41 PM
did you correctly reattach/bracket the wastegate?
if you didn't do that it could easily be the source of your problem |
Sep 23, 2007 - 12:51 PM
QUOTE(playr158 @ Sep 23, 2007 - 1:41 PM) [snapback]598333[/snapback] did you correctly reattach/bracket the wastegate? if you didn't do that it could easily be the source of your problem pretty sure i did but i guess i can check again when it quits raining -------------------- ![]() BOOST GETS YOU LAID!!!! |
Sep 23, 2007 - 1:59 PM
well upon furthur inspection the coupler comming off the turbo is hitting the mount for the tranny and i think it cut a lil hole in it but even if it did would it be able to boost?
| Lo-Fi Version | Time is now: July 30th, 2026 - 5:09 PM |
