> 5sfte problem
post Sep 13, 2007 - 5:44 PM
1994toyotaracer
Joined Sep 2, '05
From delaware
hey guys well i installed my trubo kit and everything bolts up but i am having a problem first the turbo leaks but that no big deal i will rebuild that but my main comcern is the car wont go past 4500rpms and feels sluggish i have 460cc injectors and have timing set to 8 (10 is stock) no boost controller hook up. i dont know what to do its rich at idle and has no power up to 4500 rpms and it wont go past that.i believe its timing related but i dont know so any thoughts are appriciated.
thanks
Replies (1 - 4)
post Sep 13, 2007 - 6:42 PM
what are you using for tuning?
post Sep 14, 2007 - 7:47 AM
1994toyotaracer
Joined Sep 2, '05
From delaware
QUOTE(presure2 @ Sep 13, 2007 - 6:42 PM) [snapback]595826[/snapback]
i dont have my emange ultimate hooked up yet i was just trying to see if there was a base adjustment before hooking up a management system. iknow how u were saying timing get all messed up from the boost but i was wondewring why my car wont go past 4500 rpm you know.
thanks
post Sep 14, 2007 - 8:18 AM
blckcelica95
Joined Nov 20, '03
From Derry, NH
QUOTE(1994toyotaracer @ Sep 14, 2007 - 12:47 PM) [snapback]595960[/snapback]
thanks
you really need to hook up the emange up . you are dumping way to much fuel and ist probally cuaseing the car not to go past 4500 rpm i had the same problem with my car .
Driving a 5SFTE and LOVIN IT!!!!!!
http://www.myspace.com/17psicelica <-- celica engine build pics
post Sep 14, 2007 - 12:11 PM
Panswed
Joined Jun 29, '07
From Fall River, MA
QUOTE(blckcelica95 @ Sep 14, 2007 - 8:18 AM) [snapback]595965[/snapback]
thanks
that is exactly why.
you NEED to have the fuel management hooked up, dont worry about timing right now.
you'll need to pull 20+ % of your duty cycle at idle to get it to idle well.
Lo-Fi Version Time is now: August 28th, 2026 - 8:38 AM
