Sep 15, 2007 - 2:18 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
couple questions before i start this project..
how long would the stock 7afe rods hold up when used after swapped to 7age? is it possible to use the 4age rod/bolts in the 7age? is it worth it to shot peen n crack test the 7afe rods for the swap? i PM'd nik about the 7age swap, so hopefully i get some other answers from him while gettin some more info from the rest of the 6gc community. thanks for any help guys! xav -------------------- ![]() Pandelica 2.0 in progress. |
Sep 15, 2007 - 12:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
A bunch of info is in the sticky for engine specs
http://www.6gc.net/forums/index.php?showtopic=24821 http://www.club4ag.com/faq%20and%20tech_pa...%20and%207A.htm -------------------- JDM guy made me do it.
Sep 18, 2007 - 4:06 AM
7AFE rods will probably do ok with a somewhat stockish 7AGE build... but I wouldn't bet on it in the long run if you wanna blast the sucker beyond 7500 rpms daily. 4AGE rods will NOT work.
-------------------- "It's ok to be naked girl... I'm an artist!"
Sep 18, 2007 - 10:05 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
sorry for the late reply
you can bolt the 4age head right on to the 7afe block the tuff stuff rerouting your coolant timing (this is the hardest part) new 4ag crank gear (easy) 944 belt you need after market cam gears best please for info beside people that have done the build http://te51levin.superjamie.net/7ageintro.html -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 18, 2007 - 4:38 PM
thanks for the info nik! imma get on this before winter comes rollin along hopefully have it done by thanksgiving
Sep 20, 2007 - 8:06 PM
![]() Enthusiast ![]() Joined Jan 22, '07 From phoenix, AZ Currently Offline Reputation: 0 (0%) |
QUOTE(Kwanza26 @ Sep 18, 2007 - 9:06 AM) [snapback]596928[/snapback] 7AFE rods will probably do ok with a somewhat stockish 7AGE build... but I wouldn't bet on it in the long run if you wanna blast the sucker beyond 7500 rpms daily. 4AGE rods will NOT work. if i did want to run the engine harder, what kind of rods should i use? |
Sep 21, 2007 - 10:05 AM
QUOTE(Razgriz @ Sep 20, 2007 - 6:06 PM) [snapback]597698[/snapback] QUOTE(Kwanza26 @ Sep 18, 2007 - 9:06 AM) [snapback]596928[/snapback] 7AFE rods will probably do ok with a somewhat stockish 7AGE build... but I wouldn't bet on it in the long run if you wanna blast the sucker beyond 7500 rpms daily. 4AGE rods will NOT work. if i did want to run the engine harder, what kind of rods should i use? your only 2 opt. after stock are custom or puater rods heres a pic from my build ![]() ![]() ![]() ![]() ![]()
This post has been edited by nik: Sep 21, 2007 - 10:07 AM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 21, 2007 - 1:29 PM
man. those babies are beefy. how much they cost? $700-1000?
| Lo-Fi Version | Time is now: August 1st, 2026 - 9:38 AM |
