Sep 20, 2007 - 1:53 PM
Enthusiast ![]() ![]() ![]() Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
Ok, I've decided to sell my car. I need the money for school.
I'll start off with the description followed by what the car needs. 1994 GT 107,000 miles on body Engine was taken out of a 92 USDM Alltrac which originally had approx. 180K miles Engine was rebuilt w/ the following: Valve Stem Seals Valves re-shimmed back to factory specs Head cleaned Cylinders honed and checked, block tanked Later work that was done Engine torn down and rebuilt: Arias forged pistons Eagle H-beam rods Cylinders bored 1mm over to fit the larger pistons and honed Cometic MLS headgasket Every single seal and gasket replaced New OE water pump and oil pump Every timing belt pulley was replaced with original Toyota parts Goodyear Gatorback timing belt That's it for the internal engine and what not.. Other work that was done: Custom fab intake plenum, roughly twice the size of the stock plenum w/ side mounted throttle body. Affectionatly called the "Mail Box". TVIS removed Brand new Garrett GT2871R turbo: T25 turbine housing .86 A/R Compressor: 71mm wheel, 2.75" inlet w/ .50 A/R (Place I bought it from, http://www.himni-racing.com/index.php?main...;products_id=6) Stainless steel braided coolant lines to the turbo, stainless steel oil line to the turbo. Tial 38mm external wastegate which dumps into the mid-section of the downpipe for smooth flow. Forge Motorsport Diverter Valve which dumps the excess boost air back into the intake right before the turbo. OBX Stainless tubular exhaust manifold, very small and light AND RELIABLE! 2.5" 409 Stainless FMIC Piping Massive bar and plate FMIC IC Piping is run through the driver side fender behind the fuse box to the throttle body. Very clean install. Apex'i AVC-R Electronic Boost controller 3" Custom made over-axle turbo back exhaust w/ a magnaflow muffler AEM Wideband O2 sensor Cheap oil pressure/boost gauge. (I never look at the boost gauge anyway, I mounted the AVC-R at eye level right above the hazzard button and it is very accurate.) Gauges are mounted in a din-slot below the head unit. New alternator and belt WORKING AIR CONDITIONING!!! (all it really needs is the idle up valve.. engine sometimes stalls if you are idling with A/C on but if you are driving the AC works great) Yes it has power steering as well. I think that about covers the engine stuff... I'm sure there is something I am missing. The transmission: 99 Camry V6 E153 Trans 95 JDM MR2 Turbo LSD Stage 3 6 puck clutch 11lb Chromoly flywheel Brand new Toyota inner axle stubs w/ custom made passenger side spacer Outter axles are lifetime warranty auto store parts Rear trans mount has the polyurethane inserts. The front mount does not, didn't like all the vibration. I will include the front inserts. Ahh I almost forgot! The oil filter has a front mounted cooler, the filter itself is mounted on a bracket on the passenger side frame rail to the front of the A/C compressor. The interior is .. 90% clean and in GOOD condition. WHAT THE CAR "NEEDS" Driver side fender needs replacing, passenger side fender has some chips from removing the bumper n what not.. so it could also use a replacement. The driver side door is banged up long the fender line. Other than that the body is in good shape and the paint is good. The engine runs great, pulls strong and is reliable. As a whole the car is fantastic. I have video's of it on the dyno before I did the second rebuild with the forged internals and the intake mods and what not. On the dyno I put down 289whp & 298ft/lb at 14psi, 4th gear redlined and the speedo was reading a 140mph! Unfortunately 14PSI was the max I could because of fuel limitations. What this engine REALLY needs now is larger injectors, pump and a good standalone computer to unleash it's full potential. As it is now I daily drive it and I get around 23-25mpg highway and around 19-20mpg city.. A full tank used for all city driving I'll get around 300miles. So even though it has lots of power to be used, if you drive it sensibly you still get impressive gas mileage. Things on the car I am keeping: Rims (7th gen GTS rims) Head unit That's really it.. Hell even the rims and head unit are negotiable lol. The front and rear has 1/4" rim spacers as well. I will put pictures up in a little while. I am asking $14,500 negotiable for SERIOUS BUYERS Do not Call me or PM me asking if I can do 8grand today or some crap. Serious buyers only! For more information you can PM me on here or call me 610-597-1490 -Steve This post has been edited by Punisher: Sep 20, 2007 - 2:49 PM -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Punisher FS: 94 Celica GT w/ 2nd gen 3sgte swap Sep 20, 2007 - 1:53 PM
x_itchy_b_x pics? PICS!!! must have pics... Rabble... Sep 20, 2007 - 2:31 PM
Punisher As I said, I'll get pics up in a little bit. Sep 20, 2007 - 2:48 PM
Punisher More pics to come, I have to clean out the interio... Sep 24, 2007 - 11:22 AM
Punisher 12,500 Sep 25, 2007 - 3:00 PM
Punisher This car has GOT TO GO...
I'm dropping the p... Sep 27, 2007 - 3:36 PM
99GT Money shots!!! Sep 27, 2007 - 4:44 PM
Punisher http://tekphobia.com/Alltrac/gtpics/trunk.jpg
http... Sep 29, 2007 - 5:10 PM
Punisher It's on ebay now..
http://cgi.ebay.com/ebaymot... Sep 29, 2007 - 6:28 PM
qmoney10457 http://www.6gc.net/forums/index.php?showtopic=5129... Sep 30, 2007 - 12:47 AM
Punisher QUOTE(qmoney10457 @ Sep 30, 2007 - 1... Oct 4, 2007 - 1:37 PM
celicanice QUOTE(Punisher @ Oct 4, 2007 - 1:37 ... Oct 4, 2007 - 5:50 PM
Punisher No takers here? 7200.00 .. u can't beat that..... Oct 8, 2007 - 2:21 PM
99GT I think there are tons of potential buyers, but th... Oct 10, 2007 - 7:33 PM
Punisher I know.. vehicles 10yrs or older u can't get a... Oct 11, 2007 - 3:00 PM
99GT 4,000 Oct 11, 2007 - 6:38 PM
Punisher Ok.. 4G .. u get the engine and transmission... Oct 12, 2007 - 8:21 PM
99GT That's actually a great price too. Damn bills... Oct 12, 2007 - 10:42 PM
Punisher 6500 for the car.. i'm moving to the west coas... Oct 20, 2007 - 2:42 PM
lagos QUOTE(Punisher @ Oct 20, 2007 - 3:42... Oct 20, 2007 - 3:05 PM
kerosene wow from 14.5 to 6.5 damn 110% drop... somoeone ju... Oct 20, 2007 - 4:26 PM
Punisher I might just end up parting it out.. I just need t... Oct 20, 2007 - 5:14 PM
cHinaman727 QUOTE(Punisher @ Oct 20, 2007 - 10:1... Oct 20, 2007 - 11:15 PM
kerosene 4runners are fun offroad, i got a 01 guzzles gas p... Oct 20, 2007 - 7:06 PM
Punisher 6.5 flat.. no trades unless you have a nice older ... Oct 21, 2007 - 1:21 PM
cHinaman727 QUOTE(Punisher @ Oct 21, 2007 - 6:21... Oct 21, 2007 - 1:47 PM
Punisher ANyone interested in this for 6grand? I mean hell ... Oct 24, 2007 - 12:09 PM
99GT I wish I had $6000 lying around. Oct 24, 2007 - 3:17 PM
cHinaman727 ill give you my laptop and 3k
man if i had 6k on... Oct 24, 2007 - 3:23 PM
Punisher credit card? lol
I need a laptop.. but uh.. ya i ... Oct 24, 2007 - 5:37 PM
cyb593 to bad yuou wouldnt take anything besides a 4 runn... Oct 24, 2007 - 8:22 PM
Punisher Why would I take a stock celica in trade? I'm ... Oct 24, 2007 - 11:27 PM
cHinaman727 i bought this laptop for 3.5k just so you know
w... Oct 24, 2007 - 11:45 PM
6strngs if only I could take out a loan for it... Oct 25, 2007 - 12:14 AM
Punisher I don't need a laptop that expensive lol Oct 25, 2007 - 2:03 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 12th, 2026 - 7:30 AM |
