Sep 22, 2007 - 2:15 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
i cant read the blow up chart for my turbo very well so what the heck is this?
![]() i'd throw out there what i thought but i obviously dont know what it is. -------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Sep 22, 2007 - 2:31 PM
nvm ignore stupid post.
its a water cooling port! its dual-coolant ports (oil and water) so how do i hook up the water/coolant lines to that? i've also heard most (not all people) go with the water coolant, they just cap it off... but i want to water cool it! -------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Sep 22, 2007 - 2:51 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
don't cap it off. ur gonna need sum type of adaptor, so that there well be 2 lines coming out of it. Those lines will T into the throttle body coolant lines which is an ez way.
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Sep 22, 2007 - 5:24 PM
this bad boy?
the one im pointing to
Sep 22, 2007 - 6:00 PM
![]() now this is a good one its capped off with a 8mm bolt but i removed it for the picture. and that previous image is still a live question... but im pretty sure im right with that being the TB coolant line to T into. but how would i run the feed and return? -------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Sep 22, 2007 - 6:05 PM
dual cool is very nice....just T-fitting one of your coolant lines and run it to the turbo and then same process for the drain
This post has been edited by playr158: Sep 22, 2007 - 6:06 PM |
Sep 22, 2007 - 6:44 PM
ahhh mmmhmmm i talked to tweak he said the same thing almost, just put it in-line with the coolant line and i should be set instead of t'ing. ;D
| Lo-Fi Version | Time is now: April 14th, 2026 - 3:46 AM |
