Sep 26, 2007 - 10:12 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
Hey guys, i was wondering if all headgaskets are the same? in bore size i mean, im looking into buying a metal head gasket and want to know if i need to specify that my block is bored 20 over (.020). I think im gonna buy an ACL one (the people that make bearings ;p) so can someone be so kind as to telling me what I have to torque the head bolts to? also should 1mm thick be fine or should i get a thicker one?
Sep 27, 2007 - 6:07 PM
waiting........:-(
Sep 28, 2007 - 8:09 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
HG have a slightly larger bore than the cylinders to allow for overboring.
As for how thick you need, that depends on what C:R you want. Keep in mind if the head and/or block have been machined this will lower your C:R. The head bolt torque will also depend on what HG you use and what head bolts you use [might as well get studs if you're tearing into it]. -------------------- ![]() |
Oct 3, 2007 - 9:12 AM
Anyway you can piont me to where I can buy one other than ebay? Thanks:)
Oct 3, 2007 - 4:22 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
most 3S-GTE hae gasket com 88MM that should be good even if you went 60 over the stock bore...
Oct 4, 2007 - 4:20 PM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) |
Out of curiousity what are the differences between 5S-FE and 3S-GTE headgaskets. Can they be interchanged (i.e. can you use a 3S-GTE head gasket on a 5S-FE without modification?)?
Anyone have pictures comparing the heads, blocks, gaskets of the two engines? -------------------- |
Oct 5, 2007 - 11:15 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
QUOTE(WALKER @ Oct 4, 2007 - 5:20 PM) [snapback]601703[/snapback] Out of curiousity what are the differences between 5S-FE and 3S-GTE headgaskets. Can they be interchanged (i.e. can you use a 3S-GTE head gasket on a 5S-FE without modification?)? Anyone have pictures comparing the heads, blocks, gaskets of the two engines? ^ no they are not interchangable. 3sgte = 2.0l 5sfe = 2.2l cylinder diameter is different, so there for the HG has a different hole diameter. -------------------- ![]() Kawi Love |
Oct 5, 2007 - 12:31 PM
QUOTE(devilsden97 @ Oct 5, 2007 - 10:15 AM) [snapback]602046[/snapback] QUOTE(WALKER @ Oct 4, 2007 - 5:20 PM) [snapback]601703[/snapback] Out of curiousity what are the differences between 5S-FE and 3S-GTE headgaskets. Can they be interchanged (i.e. can you use a 3S-GTE head gasket on a 5S-FE without modification?)? Anyone have pictures comparing the heads, blocks, gaskets of the two engines? ^ no they are not interchangable. 3sgte = 2.0l 5sfe = 2.2l cylinder diameter is different, so there for the HG has a different hole diameter. Well the 3S head can go on the 5S block. The cylinder bore is 86mm (3S-GTE) vs 87.1mm (5S-FE), therefore if the gasket bore is 88mm, I would think it would work on both. Just curious, that is why I would like to see a picture of a 3S head or gasket and a picture of a 5S head or gasket. -------------------- |
Oct 5, 2007 - 4:55 PM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) |
QUOTE(alltracman78 @ Sep 29, 2007 - 1:09 AM) [snapback]599957[/snapback] As for how thick you need, that depends on what C:R you want. Keep in mind if the head and/or block have been machined this will lower your C:R. I thought machining those two would increase C:R. (that's what you must have meant) QUOTE(WALKER @ Oct 5, 2007 - 5:31 PM) [snapback]602085[/snapback] QUOTE(devilsden97 @ Oct 5, 2007 - 10:15 AM) [snapback]602046[/snapback] QUOTE(WALKER @ Oct 4, 2007 - 5:20 PM) [snapback]601703[/snapback] Out of curiousity what are the differences between 5S-FE and 3S-GTE headgaskets. Can they be interchanged (i.e. can you use a 3S-GTE head gasket on a 5S-FE without modification?)? Anyone have pictures comparing the heads, blocks, gaskets of the two engines? ^ no they are not interchangable. 3sgte = 2.0l 5sfe = 2.2l cylinder diameter is different, so there for the HG has a different hole diameter. Well the 3S head can go on the 5S block. The cylinder bore is 86mm (3S-GTE) vs 87.1mm (5S-FE), therefore if the gasket bore is 88mm, I would think it would work on both. Just curious, that is why I would like to see a picture of a 3S head or gasket and a picture of a 5S head or gasket. Makes sense for the 3s HG to go on a 5s block. Pics would be nice, (if only ice with his 5s-gte had some pics of the diff. HG) -------------------- ![]() CLOSED on 25 acres! -shop coming soon.... |
Dec 18, 2007 - 4:10 AM
Enthusiast Joined Dec 11, '07 From Norway Currently Offline Reputation: 0 (0%) |
Any headgasket that's interchangable for the 7A-FE ?
Or any know who that sells reinforced ones for this engine? |
Dec 18, 2007 - 6:35 AM
QUOTE(Turbofun @ Dec 18, 2007 - 4:10 AM) [snapback]623807[/snapback] Any headgasket that's interchangable for the 7A-FE ? Or any know who that sells reinforced ones for this engine? toyota sells a metal headgasket for the 7a. the 3s and 5s gaskets are not interchangeable because of the water jackets in the gasket dont line up from motor to motor. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: July 11th, 2026 - 9:11 PM |
