Sep 28, 2007 - 8:16 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
whats up guys... having yet another issue with this coupe i have. To my SURPRISE it over heated earlier today on my way to get the oil changed, when i finally realized what was going on i put some water in it and put 4 fresh quarts of oil in it and was on my way. car was fine until tonight here's what happened.
doing about 65 on highway hear a slight pop or bump sound car looses mechanical power car will not start (it spins as if it wants to start but wont run dont hear any clanking noise indicating thrown rod) checked to see if oil was under the car I checked to see if the head gasket is blown (oil not milky nor does it have metal flakes in it) checked the resorvoir for the radiator i am ABSOLUTLEY CLUELESS as to what happened. no tools to check if the timing belt broke Im beginning to question this car, only had it since may and there have been silly things since the day i got it... LITERALLY the day i got it. what do you guys think may have happened? This post has been edited by easternpiro1: Oct 3, 2007 - 10:46 PM -------------------- |
easternpiro1 Got the belt on, it started smoking... Sep 28, 2007 - 8:16 PM
presure2 my guess is tbelt.
pull the distributor cap, and ... Sep 28, 2007 - 9:15 PM
easternpiro1 i was also wondering if low oil could cause it to ... Sep 29, 2007 - 9:14 AM
Black2na sounds like you did some damage. low oil would cau... Sep 29, 2007 - 9:21 AM
easternpiro1 QUOTE(Black2na @ Sep 29, 2007 - 9:21... Sep 29, 2007 - 10:41 AM
Black2na well just cause you checked it doesn't mean th... Sep 29, 2007 - 10:48 AM
easternpiro1 ok finally got the car towed from off of the highw... Sep 29, 2007 - 6:19 PM
alltracman78 QUOTE(easternpiro1 @ Sep 29, 2007 - 6... Sep 29, 2007 - 8:14 PM
TRD_GT u could always try and see if you have any oil pre... Sep 29, 2007 - 6:46 PM
lagos how low was the oil? and why didnt you keep it to... Sep 29, 2007 - 7:03 PM
easternpiro1 QUOTE(lagos @ Sep 29, 2007 - 7:03 PM... Sep 29, 2007 - 8:50 PM
easternpiro1 found out that it was the timing belt (thank GOD) ... Sep 30, 2007 - 4:26 PM
trdss111 QUOTE(easternpiro1 @ Sep 30, 2007 - 4... Sep 30, 2007 - 7:38 PM
jcaron9gt4 QUOTE(trdss111 @ Sep 30, 2007 - 8:38... Sep 30, 2007 - 8:10 PM
easternpiro1 thats right! jcaron..we are trying to do it ou... Sep 30, 2007 - 9:40 PM
presure2 it helps if you lower that side of the engine abit... Sep 30, 2007 - 9:50 PM
lagos dont you still have your 3s? why dont yo just swap... Sep 30, 2007 - 9:57 PM
easternpiro1 QUOTE(lagos @ Sep 30, 2007 - 9:57 PM... Sep 30, 2007 - 10:17 PM
Batman722 take the front and rear mount out and support the ... Sep 30, 2007 - 10:55 PM
easternpiro1 QUOTE(Batman722 @ Sep 30, 2007 - 10... Sep 30, 2007 - 11:01 PM
lagos you have to undo that passengers side motor mount.... Sep 30, 2007 - 11:13 PM
easternpiro1 we took off the passenger side mount. it wouldnt t... Sep 30, 2007 - 11:27 PM
easternpiro1 i see why it costs so damn much for timing belt ch... Sep 30, 2007 - 11:36 PM
lagos http://www.celicatech.com/93rmsour/1993/93...a/em/... Oct 1, 2007 - 12:05 AM
easternpiro1 thanks bro, but i have a 7a, i looked to see if an... Oct 1, 2007 - 12:22 AM
easternpiro1 ok got everything on, my boy put the cover and eve... Oct 3, 2007 - 10:49 PM
alltracman78 Hard to tell from 1000 miles away...
Before you r... Oct 4, 2007 - 2:42 PM
easternpiro1 QUOTE(alltracman78 @ Oct 4, 2007 - 2... Oct 4, 2007 - 11:48 PM
alltracman78 QUOTE(easternpiro1 @ Oct 4, 2007 - 11... Oct 5, 2007 - 1:26 PM
easternpiro1 QUOTE(alltracman78 @ Oct 5, 2007 - 1... Oct 5, 2007 - 4:45 PM
lagos mechanic at a car dealer doesnt mean a whole lot. ... Oct 5, 2007 - 12:34 AM
easternpiro1 good point lagos, but he actually does more. we wi... Oct 5, 2007 - 12:54 PM
alltracman78 No
The accessory belts are totally separate from ... Oct 5, 2007 - 6:04 PM
easternpiro1 QUOTE(alltracman78 @ Oct 5, 2007 - 6... Oct 5, 2007 - 8:12 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 18th, 2026 - 9:07 PM |
