Oct 3, 2007 - 12:33 PM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
hey Im looking for a qualtiy amp to mate with my Clarion HXD2...anyone has any recommendations?? Im looking for class A but AB is ok...
Btw any comment on the SoundStream TR800/5 amp? ![]() -------------------- ![]() 98% completion --- aaRon |
Oct 3, 2007 - 1:43 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 4, '07 From US Currently Offline Reputation: 2 (100%) |
bloody nice, expensive though.... soundstream is competition quality so you really cant go bad with it, but then get a quality sub... just a **** one be very good
Oct 3, 2007 - 1:49 PM
What class is this TR800/5 amp, anyone knows? Ive searched hours but not a single site state what class it is...
Oct 3, 2007 - 2:28 PM
Amplifier Type Multi Channel <-- means its not mono, but class D(not for sub, would be used for speakers)
Amplifier Output 5-channel RMS Power 50 Watts x 4 + 200 Watts x 1 -- 50W x 4 at 4 ohm stereo, 200x1 100W x 4 at 2 ohm stereo, 400x1 200W x 2 at 4 ohm Mono, 400x1 RUBI (Rapid-Use Branched Impulse) Trident Amplifier protection topology Tone Sweep Calibration Hawkins Bass Control Continuously variable 12dB low-pass crossover (30Hz to 4kHz) Three Stage Input Level Indicators Output Clip Indicators IDI (Intelligent Distress Indicator) Large Mouth Bass remote gain control Continuously variable phase alignment (0 - 180) Vortex induction fan Differentially Balanced RCA Input Fully Balanced 6-pin DIN Input RCA Line Output Gold plated 1/0 gauge power inputs Harmonic Bass Alignment Discrete Balanced Class A Drive Boards Drive Delay 2 Chassisink Transistors Power Grid 20Hz 500 Hz Frequency response 115dB S/N ratio 500 Damping 300mV 5.0V Input sensitivity 0.02% THD All Chrome Plated --- This post has been edited by kerosene: Oct 3, 2007 - 2:31 PM |
Oct 3, 2007 - 2:50 PM
kerosene where you get that info from???
where I got it from, it says Discrete Balanced Class A Drive Boards.. http://www.woofersetc.com/index.cfm?fuseac...;Product_ID=553 BTW just found this amp SoundStream Da Vinci 7channels...all the power I ever need to run a whole system. http://www.woofersetc.com/index.cfm?fuseac...;product_id=537 -------------------- ![]() 98% completion --- aaRon |
Oct 3, 2007 - 4:12 PM
stick to the turantula series, that is one of the best they have... |
Oct 3, 2007 - 4:45 PM
QUOTE(kerosene @ Oct 4, 2007 - 5:12 AM) [snapback]601249[/snapback] http://www.woofersetc.com/index.cfm?fuseac...;Product_ID=553 stick to the turantula series, that is one of the best they have... I thought the Da Vinci susposed to be better..no??? Im gonna buy one of these amp probably today...kerosene, do you care to explain why the turantula is better than the Da Vinci?? -------------------- ![]() 98% completion --- aaRon |
Oct 3, 2007 - 4:48 PM
from what ive used when i used to enter competitions, those always seemed to be the most stable, last longer, dont overheat as much as the others... I cant for sure say da vinci is bad, but my recommendation is stick with the tarantula series... but than agian, if you have the oppertunity to test em, see which you like....
Oct 3, 2007 - 5:03 PM
the problem is..i cant test them. I know for a fact that the Da Vinci was a Limited Edition and was intended to be one of the best, but then again the TR800 specs is not bad...
OHHH its that feeling again...the vulnerable feeling of being unable to choose something.. *&*(&*(DHY -------------------- ![]() 98% completion --- aaRon |
Oct 3, 2007 - 5:06 PM
gimmi 5 min ill call my m8, hes still in competitions so he will know
**** hes not around.... lemme look around and compare.... wow, that da vinci is very impressive but on subwoofer you only get 500 watts...is that enough? This post has been edited by kerosene: Oct 3, 2007 - 5:12 PM |
Oct 3, 2007 - 5:18 PM
yea that should be enough...thanks alot
i got the pdfs for two of them but on the Da Vinci I couldnt figure out if it has independent SL and SR sub input...it probably does but im not sure.. da vinci tr800 This post has been edited by lubu: Oct 3, 2007 - 5:24 PM -------------------- ![]() 98% completion --- aaRon |
Oct 3, 2007 - 8:48 PM
by SR you mean slew rate?
Oct 4, 2007 - 1:40 AM
QUOTE(kerosene @ Oct 4, 2007 - 9:48 AM) [snapback]601328[/snapback] by SR you mean slew rate? no...sub right..sub left -------------------- ![]() 98% completion --- aaRon |
| Lo-Fi Version | Time is now: August 4th, 2026 - 4:43 PM |
