Oct 11, 2007 - 9:37 AM
Enthusiast ![]() ![]() ![]() Joined Jul 29, '03 From north of detroit Currently Offline Reputation: 6 (100%) |
hey everybody. i'm in a bit of a hurt and i hope somebody can give me some insight.
my 5sfe didn't start today. i've NEVER had a problem with it before. the starter runs but the engine won't turn over. it's damp and rainy today, for what it's worth. it has a full tank of 91 octane, the battery connections are tight, and all the plug wires are connected properly. with the gracious help of my neighbors, we tried push-starting it several times, but as soon as the clutch pops, the engine makes a horrible diesel-decompression sound and the tires just skid (maybe because of the wet ground) i'd like to replace the plugs, wires, coil, dizzy, etc. but i'm hoping someone can help narrow it down. i will do my best to provide any additional info if needed. thanks. -------------------- ![]() do you know who i am, mr. worley? |
uberschall OH NO celica won't turn over, advice needed Oct 11, 2007 - 9:37 AM
uberschall anything helps. it's going to be cold and dar... Oct 11, 2007 - 1:37 PM
Stu37363 QUOTE(uberschall @ Oct 11, 2007 - 2... Oct 11, 2007 - 2:02 PM
x_itchy_b_x your going to have to determine what element your ... Oct 11, 2007 - 2:26 PM
uberschall stu - i'll check the ignition fuse first thing... Oct 11, 2007 - 4:32 PM
uberschall ignition fuse - ok
ecu fuse - ok
i pulled off one... Oct 11, 2007 - 6:32 PM
95CelicaST distributor, ignitor, coil, ignition... you've... Oct 11, 2007 - 6:40 PM
uberschall QUOTE(95CelicaST @ Oct 11, 2007 - 7... Oct 11, 2007 - 6:59 PM
Bitter replace the cap and rotor, moisture can get under ... Oct 11, 2007 - 9:17 PM
uberschall i'll see if i can find parts tomorrow...won... Oct 12, 2007 - 12:02 AM
uberschall actually, i just realized i don't know how to ... Oct 12, 2007 - 7:59 AM
garygarrett1 I am having the same problem with mine so I feel y... Oct 12, 2007 - 10:04 AM
uberschall if you're curious how this is going for me, he... Oct 13, 2007 - 6:42 PM
uberschall back to the drawing board, thing didn't start ... Oct 15, 2007 - 9:53 AM
95CelicaST Sad news..
I am down with the same issue right no... Oct 15, 2007 - 10:04 AM
uberschall okay, moving along then.
i pulled my efi relay. ... Oct 15, 2007 - 11:27 AM
95CelicaST If I am reading the EFI relay diagram properly, yo... Oct 15, 2007 - 11:35 AM
uberschall i'm going to say it's fine because the res... Oct 15, 2007 - 11:45 AM
uberschall nix the cap and rotor, if it were burned up, the t... Oct 15, 2007 - 12:01 PM
uberschall the only thing i know so far is that the problem i... Oct 16, 2007 - 9:50 AM
95CelicaST so the moisture in the air is causing a short some... Oct 16, 2007 - 12:51 PM
uberschall i checked every connection i could. i live in an ... Oct 16, 2007 - 4:58 PM
nightryder judging by the randomness of the "non-starts... Oct 17, 2007 - 9:50 AM
95CelicaST ignitor is on top of the coil.
It might just be t... Oct 17, 2007 - 9:57 AM
uberschall well, it was the distributor. it had actually mel... Oct 18, 2007 - 8:30 PM
95CelicaST Awesome. Thats good to hear. I'm glad it wasn... Oct 18, 2007 - 8:33 PM
uberschall QUOTE(95CelicaST @ Oct 18, 2007 - 9... Oct 18, 2007 - 9:25 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 7:58 AM |
