Aug 11, 2003 - 3:19 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 31, '03 From GA Currently Offline Reputation: 0 (0%) |
I just bought my 6th gen (96 ST) not to long ago. Not knowing when the most recent oil change was I decided to go ahead and do it. I went and picked up an oil filter (Purolator $3.50---good choice?) and I have some Castrol GTX 10w 30. Get under my car and find the oil filter(beneath the exahuast manifold) and think I find the drain bolt. Basicaly just about 12 inches below the filter. REally i just want to veriffy this is the right bolt. Also is that oil and filter a good recomendation for my car ( 138,000 miles).
*edit*I tried to undo the bolt and just couldnt get it off. I"m going to try again in a little bit. Would much prefer to do this myself. Cormudgen |
Cormudgen oil change Aug 11, 2003 - 3:19 PM
phat94celi The drain plug is on the oil pan. It is the only ... Aug 11, 2003 - 3:29 PM
Stipt If its on the passenger side, bingo! Ya gots ... Aug 11, 2003 - 9:51 PM
sonar What is the best oil for our Celica anyway? Apr 15, 2004 - 9:35 PM
celicarocker i had that problem with mine. just get a breaker b... Apr 15, 2004 - 9:56 PM
Pali_playa synthetic oil by quaker state i think Apr 15, 2004 - 10:02 PM
playr158 i use either fram or super tech..works good for me Apr 15, 2004 - 10:02 PM
LatinKraze I use 10w 40, but i have 179,000 miles on the cloc... Apr 16, 2004 - 11:19 AM
Silver94CelicaOwner I use Castrol GTX 10w 30 too and i think it does a... Apr 16, 2004 - 11:50 AM
BigEdge169 I use Valvoline Maxlife 10W-30 and it seems to wor... Apr 16, 2004 - 12:00 PM
Drocay Mobile One Synthetic: Older Engine Formula (for ca... Apr 16, 2004 - 12:29 PM
Drocay K&N filters are good and are like 20 less than... Apr 16, 2004 - 12:30 PM
Sirius How much is a standard Toyota filter over there?
... Apr 16, 2004 - 2:16 PM
Digndoug ok, a filter is really all the same. Get a fram, t... Apr 16, 2004 - 4:06 PM
Chrobis umm wow... all you guys using synthetic oil in you... Apr 16, 2004 - 4:19 PM
Jeremy1210 I think you might be worng with the 5w-30 oil. My ... Apr 17, 2004 - 1:18 PM
aaronc222 Very wrong on a few points. Synthetic oil provides... Apr 17, 2004 - 1:46 PM
Chrobis well for the 5s its 5w-30, and all I was saying is... Apr 17, 2004 - 10:18 PM
x_itchy_b_x Mobile One Synthetic is what i use. 10w-30
why use... Apr 17, 2004 - 10:37 PM
Justin I just put 10w-40 in my car. a mechanic that i kno... Apr 18, 2004 - 2:07 PM
aaronc222 QUOTE (Chrobis @ Apr 17, 2004 - 11:18 PM) well for... Apr 18, 2004 - 2:41 PM
SlowCelica94 Bosch makes some great oil filters and at only ... Apr 18, 2004 - 7:24 PM
wind the numbers are viscosity (sp) when it is cold it ... Apr 18, 2004 - 8:29 PM
x_itchy_b_x QUOTE (wind @ Apr 18, 2004 - 9:29 PM) the numbers ... Apr 18, 2004 - 8:34 PM
wind QUOTE (x_itchy_b_x @ Apr 19, 2004 - 1:34 AM) QUOTE... Apr 20, 2004 - 1:59 AM
elvasoshexai uh... is this the right gasket for the oil drain p... Nov 7, 2006 - 11:40 PM
LewFX theres a gasket on the filter...put some oil on it... Nov 7, 2006 - 11:49 PM
BLADDER_MASTER 10W-30 Mobil 1 Synthetic Oil with Toyota OEM Filte... Nov 8, 2006 - 2:08 AM
6strngs my oil cap on my 5sfe it says 10w-30
according to... Nov 8, 2006 - 3:10 AM
6gsillyca can anyone tell me what the "recommended... Nov 8, 2006 - 2:03 PM
elvasoshexai ok.. i feel kinda retarded... after 6 hours i coul... Nov 10, 2006 - 12:45 AM
jc47 Get the smaller adjustable/strap wrench and put an... Nov 10, 2006 - 1:09 AM
CelicaST202 i dont even use the wrench, i can take it off with... Nov 10, 2006 - 1:40 AM
6strngs use a fat pair of pliers... just be careful not to... Nov 10, 2006 - 1:47 AM
Batman722 QUOTE(6strngs @ Nov 10, 2006 - 1:47 ... Nov 10, 2006 - 1:59 AM
jdg371 hard to take off filter? Get a long fat screwdrive... Nov 10, 2006 - 11:46 AM
99GTauto I changed the oil 2500 miles after we purchased th... Nov 13, 2006 - 11:17 AM
azian_advanced i think you can stick with 10w-30 year round... cu... Nov 13, 2006 - 11:41 AM
99GTauto Switching to 10W-30 for good on my next change was... Nov 13, 2006 - 7:47 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 6:25 AM |
