Oct 14, 2007 - 1:00 PM
Enthusiast ![]() ![]() ![]() Joined May 19, '06 From North NJ Currently Offline Reputation: 16 (100%) |
this morning when it was really cold at like 7am i tried starting my car and it fired but it went to 500 rpms and sputtered to zero and then just shut off. it wouldnt start unless i gave it gas right after it was ignited. how can i fix this?
Oct 14, 2007 - 1:02 PM
Enthusiast ![]() Joined Mar 26, '07 From CP 518 Currently Offline Reputation: 0 (0%) |
maybe you need a new alternator??
Oct 14, 2007 - 1:08 PM
clean your aic with carb cleaner...
Oct 15, 2007 - 1:23 PM
QUOTE(LewFX @ Oct 14, 2007 - 1:08 PM) [snapback]604806[/snapback] clean your aic with carb cleaner... aic? |
Oct 15, 2007 - 8:58 PM
Enthusiast ![]() Joined Mar 4, '07 From Poughkeepsie, NY Currently Offline Reputation: 0 (0%) |
QUOTE(twitchh17 @ Oct 14, 2007 - 6:00 PM) [snapback]604802[/snapback] this morning when it was really cold at like 7am i tried starting my car and it fired but it went to 500 rpms and sputtered to zero and then just shut off. it wouldnt start unless i gave it gas right after it was ignited. how can i fix this? I am kind of having the same problem. Recently, but it only happens sometimes, when I try to start my car...it kind of whines and sputters but if I hold the key turned, it starts a few seconds later but it doesn't sound good. I know for a fact its not the battery or the starter. Ive had both checked out. Any ideas? |
Oct 16, 2007 - 12:12 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
check your air filter n clean out your throttle body a lil bit. with carb cleaner.
-------------------- ![]() Pandelica 2.0 in progress. |
Oct 16, 2007 - 7:03 PM
lol naw it cant be my air filter i just bought a brand new injen replacement filter like 2 months ago. i just found out my engine was low on oil. after i filled it up with mobil 1 the car was happy again :]
Oct 16, 2007 - 7:29 PM
Enthusiast ![]() Joined Oct 1, '07 From Sacramento, CA Currently Offline Reputation: 0 (0%) |
AIC - Advanced Idle Controller - Helps control your Idle when your stopped to help conserve gas.
Thing's you can try - - New spark plugs - New fuel Injector's - New fuel filter - Most likely - Try useing the fuel Injector cleaner they have at cheveron, then, If you can afford It, Get a full tank of Ceveron supreme, that should do It. If you try these let me know If any work, or If you have already fixed the problem. |
| Lo-Fi Version | Time is now: July 30th, 2026 - 6:35 PM |
