Oct 17, 2007 - 9:22 PM
Enthusiast ![]() ![]() Joined Aug 26, '04 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
Could a streached timing belt cause boging and much louder intake growl? I was tryin home today and stalled my car in traffic, after that it bogs pretty bad at lower rpms, and almost sounds like intake valves are opening to early and causeing back pressure out my CAI.
Oct 18, 2007 - 5:34 PM
bump.... any ideas at all?
Oct 18, 2007 - 8:01 PM
yes, pull the timing cover back and feel its tension. it should be tight.
Oct 19, 2007 - 4:57 PM
Enthusiast ![]() Joined Jan 30, '06 Currently Offline Reputation: 1 (100%) |
hey.....mine's got the same problem.......i had a guy replacing my timing belt and now the car starts bogging when i go uphill on a cold engine.....i checked the belt and it's pretty tight......any1 got any ideas?Thanks
Oct 19, 2007 - 5:19 PM
Enthusiast ![]() ![]() ![]() Joined Jul 18, '06 From plymouth, MA USA Currently Offline Reputation: 0 (0%) |
i had my timming belt and water pump done and now my car makes a wineding noise all the time it runs fine has alot of power but it just makes that noise its not that loud but id wish it would go away the worse part is no one knows wat it is
Oct 19, 2007 - 6:22 PM
Timing belts don't really stretch. They'll just shear a bit then break. The tensioner could be loose and knock it out of timing, it could have skipped a tooth, or it could be something else.
QUOTE(slvr_celica_GT_816 @ Oct 19, 2007 - 10:19 PM) [snapback]606644[/snapback] i had my timming belt and water pump done and now my car makes a wineding noise all the time it runs fine has alot of power but it just makes that noise its not that loud but id wish it would go away the worse part is no one knows wat it is If the tensioner is a bit too tight, it'll squeal a bit until the belt is worn in. Unless of course it's been squealing for a while now... then it could be anything... QUOTE(lazarpaul @ Oct 19, 2007 - 9:57 PM) [snapback]606638[/snapback] hey.....mine's got the same problem.......i had a guy replacing my timing belt and now the car starts bogging when i go uphill on a cold engine.....i checked the belt and it's pretty tight......any1 got any ideas?Thanks Check your timing. If that's good, check your ignition timing. If that's good, check spark plugs and wires. -------------------- "It's ok to be naked girl... I'm an artist!"
Oct 21, 2007 - 1:41 AM
Well its not my timing belt. Swaped that out today. Got it tracked down to possible blown head gasket, or maybe 2 bad injectors
Oct 21, 2007 - 1:02 PM
Enthusiast ![]() Joined Sep 29, '06 From US Currently Offline Reputation: 3 (100%) |
QUOTE(lazarpaul @ Oct 19, 2007 - 4:57 PM) [snapback]606638[/snapback] hey.....mine's got the same problem.......i had a guy replacing my timing belt and now the car starts bogging when i go uphill on a cold engine.....i checked the belt and it's pretty tight......any1 got any ideas?Thanks try loosen it up a little, mine was pretty tight too when I installed it and it was making all kinds of weird noises. |
Oct 21, 2007 - 8:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
on an Integra me and my friend rebuilt the head, then we put the timing off my 2 notches by accident.. when it runs, low rpms, and no power untill about 3K then it seems to just explode with power. intake is pretty loud. scary loud actually, i revved it and jumped back afraid of the growl/scream it made. maybe that can help you figure out whats going on..
Oct 22, 2007 - 11:07 PM
Pulled my head off yesterday. Blew my head gasket between #1 and #2 pistons.
| Lo-Fi Version | Time is now: July 10th, 2026 - 3:37 PM |
