> 3SGTE Swap, Anything else I will need?
post Oct 18, 2007 - 9:54 AM
cv7713
Joined Sep 21, '07
From FL
The below engine may be in the near future. I have a 94 GT with the 5s. What else will I need? Will the stock cooling system be sufficient? I believe the 5s tranny bolts up correct? I would upgrade the clutch obviously. Also a new exhaust? Love the celi and just looking for a reliable engine with the great sound of a bov!! comments welcome thumbsup.gif
Donor Vehicle: JDM 90-93 Toyota Celica
Mileage: 30k-45k miles
Displacement: 1998cc
Valve train: DOHC 4 Cylinder, 16 Valve, 2.0L TURBO
Horsepower: 225 HP @ 6000 RPM
Torque: 200 LBS-FT @ 3200 RPM
Compression: 8.5:1
INCLUDED PARTS:
100% COMPLETE ENGINE
- Complete Motor
- Block
- Head
- Intake Manifold
- Exhaust Manifold
- Sensors
- Fuel Rail
- Injectors
- Cam Angle Sensor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- Pulleys
- Turbo manifold
- Turbocharger
• 5-Speed AWD Transmission
• Computer(ECU)
• Intercooler
• Complete Wiring Harness(Un-Cut)
- cv7713   3SGTE Swap   Oct 18, 2007 - 9:54 AM
- - soulshadow   Im not even sure, but does anyone know if the MR2 ...   Oct 18, 2007 - 10:23 AM
- - 99GT   5S tranny would fit. Donor car? If its a car you s...   Oct 18, 2007 - 10:32 AM
- - cv7713   it's not a clip, just the motor and all the ac...   Oct 18, 2007 - 10:43 AM
- - cv7713   OK, next BIG question... is it possible to keep ...   Oct 18, 2007 - 11:18 AM
|- - lubu   QUOTE(cv7713 @ Oct 19, 2007 - 12:18 ...   Oct 18, 2007 - 12:03 PM
- - Gary   AFM, MAP sensor,... http://www.6gc.net/forums/inde...   Oct 18, 2007 - 11:20 AM
- - cv7713   even better   Oct 18, 2007 - 1:39 PM
- - lagos   QUOTE(cv7713 @ Oct 18, 2007 - 11:43 ...   Oct 18, 2007 - 2:07 PM
- - lagos   http://www.6gc.net/forums/index.php?showtopic=2882...   Oct 18, 2007 - 2:13 PM
- - 99GT   QUOTE(lagos @ Oct 18, 2007 - 7:07 PM...   Oct 18, 2007 - 6:11 PM
- - y2komar   I am doing a swap as we speak. I have been doing ...   Oct 19, 2007 - 7:42 AM
- - cv7713   Thanks komar. looks good so far, I will be follow...   Oct 19, 2007 - 8:53 AM
- - cv7713   OK, here's what I am seeing: Complete Engine,...   Oct 19, 2007 - 11:05 AM
- - lagos   QUOTEbut I don't want to regret anything. for...   Oct 19, 2007 - 11:18 AM
- - cv7713   ok heard ya... just don't really have the spa...   Oct 19, 2007 - 11:52 AM
|- - lubu   QUOTE(cv7713 @ Oct 20, 2007 - 12:52 ...   Oct 19, 2007 - 12:16 PM
|- - y2komar   QUOTE(cv7713 @ Oct 19, 2007 - 11:52 ...   Oct 23, 2007 - 10:13 PM
- - cv7713   ok, makes sense. thanks for the explanation. was...   Oct 19, 2007 - 12:22 PM
- - 99GT   y2komar got lucky and got most of his parts. But ...   Oct 19, 2007 - 1:28 PM
- - lagos   QUOTE(99GT @ Oct 19, 2007 - 2:28 PM)...   Oct 19, 2007 - 2:04 PM
- - cv7713   QUOTE(lagos @ Oct 19, 2007 - 2:04 PM...   Oct 19, 2007 - 2:41 PM
- - lagos   you want a celica st185 clip. not an mr2 one. the ...   Oct 19, 2007 - 2:57 PM
- - cv7713   lol... well I am glad we cleared that up!...   Oct 19, 2007 - 3:02 PM
- - 99GT   Not harder, but more side things you got to do.   Oct 20, 2007 - 1:01 AM
- - Dr_Tweak   Yeah, if you have a GT then you can swap over all ...   Oct 20, 2007 - 2:13 PM
- - bccentaur3   So as long as the swapper owns a GT, by swapping a...   Oct 20, 2007 - 6:37 PM
- - Dr_Tweak   *IF* you're stuck on the idea of using an E153...   Oct 20, 2007 - 7:43 PM
Lo-Fi Version Time is now: September 1st, 2026 - 2:30 PM
