> fuel pressure regulator installation
post Oct 18, 2007 - 11:00 PM
trdwasiq
Joined Aug 15, '07
From ATLANTA
aite i bought a universal fuel pressure regulator i knw how to put it and everything but when i took out the the stock on the oval fittment goes into fuel rail has a nozzel and the after market one doesnt so anyways i put it it started the car next thing i knw its leakin fuel bad... i tried to put rtv on but fuel is just eating it >:( any body got an idea??
This post has been edited by trdwasiq: Oct 18, 2007 - 11:04 PM
KEEPIN IT LOW... WAP PRODUCTIONS... www.myspace.com/waprod
post Oct 19, 2007 - 12:51 PM
TRD_GT
Joined Jul 12, '07
From London,Great Britain
What is the regulator called and where did you buy it from..? Because i know there are some that are abit hard to fit, i cant even get one for my celica since its a 96..anywhere..it has to be built from scratch by a company called FSE..send the details of ur regulator..i might be able to help you out..
post Oct 22, 2007 - 4:25 PM
trdwasiq
Joined Aug 15, '07
From ATLANTA
idk wht company is it .. it looks like any other regualtors on ebay liek this one
http://cgi.ebay.com/ebaymotors/Carbon-Univ...sspagenameZWDVW
the other side is flat but the stock one has a nozzel goin into fuel rail.. idk wht to use i was abt to use some jb weld so fuel stays in
post Oct 22, 2007 - 5:39 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
theres a sard brand one on ebay that is well known, anyone try that one?
post Oct 23, 2007 - 7:21 PM
trdwasiq
Joined Aug 15, '07
From ATLANTA
i bought it locally the guy had it on his 240.. he said its universal but the only problem is that fuel is coming out
the nozzel is not propeply blocking it as stock one does
post Oct 25, 2007 - 3:03 PM
TRD_GT
Joined Jul 12, '07
How about this, take a look at ur standard regulator..note down how many bolts are holding urs down..what type of plate r the bolts screwed into and then give FSE a call..they will build you one from scratch specific to ur vehicle and it will fit perfectly no problem..its a UK number so its +441784493555..they should be able to do u one for about £90 which works out to about $190..
post Oct 25, 2007 - 3:35 PM
trdwasiq
Joined Aug 15, '07
From ATLANTA
why would i wana do that i am try to make mine work that i already bought:(.. there two screws on stock one and two on after market one
post Oct 25, 2007 - 3:43 PM
TRD_GT
Joined Jul 12, '07
oh yeh..forgot u bought one already..sorry dude..
post Oct 25, 2007 - 4:03 PM
FunkySR
Joined Apr 22, '07
From Buckinghamshire, UK
QUOTE(trdwasiq @ Oct 24, 2007 - 1:21 AM) [snapback]607793[/snapback]
hi ya.
Did you fit an 'o' ring between the regulator and fuel rail? also, you need some sealant.
Hope this helps.
Jason.
post Oct 25, 2007 - 4:51 PM
trdwasiq
Joined Aug 15, '07
From ATLANTA
yea i put the o ring there too but fuel still comes out man ... what type of selant should i use???
post Oct 25, 2007 - 5:04 PM
FunkySR
Joined Apr 22, '07
hi ya. when i fitted one to my 1998 tibby, i used an o ring and a sealant that did not perish with contact with fuel. forgot what it is calleed...check with your local motor factors (car parts store).
post Oct 25, 2007 - 9:28 PM
trdwasiq
Joined Aug 15, '07
From ATLANTA
i was using rtv but it didnt work i think i am gona weld that **** with jb weld or right stuff
Lo-Fi Version Time is now: September 2nd, 2026 - 3:55 PM
