Oct 18, 2007 - 11:32 PM
Enthusiast Joined Oct 18, '07 From Florida Currently Offline Reputation: 0 (0%) |
Ok here's the story.
She was driving 70 down the highway and the radiator breaks, makes lots of noise and the car dies. The car will not start. It has spark, its getting fuel, timing is 10 degrees advanced. I did a compression check and found the problem. The compression is (30 / 4 / 4 / 30 PSI) cyl 1-4. My question is could anything else other than a warped cyl head cause no compression. My mechanic says it is very unlikely to have all the cylinders lose compression from a warped cyl head. The car has 130k and drove beautifully a few days ago. If the cyl head is bad should i have it machined or buy a rebuilt engine. (trying to save money) Any suggestions? Thanks |
Oct 18, 2007 - 11:36 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
yea it makes sense that an engine gets destroyed from over heating.
did you try to poor a little oil in the cyclinder and redo the compression test? I would recomend you get a completely new engine. When an engine over heats and warps, its not the same anymore. |
Oct 18, 2007 - 11:42 PM
I have not tried putting oil in the cylinder before the compression check.
Ya i was hoping to fix this engine, but i'll start looking for a rebuilt then. I believe the car sounds different when trying to start it and it turns over slower than normal I though the sound could be from the low compression. This post has been edited by Flyboy284: Oct 18, 2007 - 11:45 PM |
Oct 18, 2007 - 11:50 PM
is the timing belt still there and hasnt skipped? can you turn the crank pulley (with a socket and ratchet) by hand easily with all the spark plugs out?
Oct 19, 2007 - 12:09 AM
Yes, the crank pulley turns easily without the spark plugs in. I did remove the valve cover and aligned the engine TDC and the belt looks like it is were it should be. (TDC indicator on crank pulley around 10 degrees).
Before the car broke down the timing was closer to 15 when running than 10 But if it slipped a notch the timing changes by a lot more than 5 degrees The timing belt was replaced about a year ago after it was destroyed from the tensioner pulley seizing. (in case it makes a difference) Thanks for the fast replys |
Oct 19, 2007 - 6:04 PM
If your compression is 30/4/4/30... chances are your engine is f***ed. Take off your oil pan and take a look.
-------------------- "It's ok to be naked girl... I'm an artist!"
| Lo-Fi Version | Time is now: July 11th, 2026 - 2:04 PM |
