Oct 28, 2007 - 5:49 PM
Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
after doing some research (and procrastinating) i have figured out that my ignition signal circuit is messed up.
that, however, is something i don't really have much knowledge of. my car wouldnt start on occasion sometimes but i figured it was just a bad starter because eventually it would start after a few tries. But me being the poor kid that i am, i never got around to fixing it. but anyways could someone please explain to me what needs to be done/ checked in detail? -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
Oct 29, 2007 - 11:48 AM
well i found a working used distributor locally for only 60 bucks, so i snagged that thinking i'll just replace the whole distributor since the igniter could be bad. well it didn't fix the problem. so what the hell else is wrong? someone give me some feedback, i really need to drive.
This post has been edited by tonytutino: Oct 29, 2007 - 11:49 AM -------------------- **If you play My Brute, joing the 6gc.net clan!**
Oct 29, 2007 - 1:42 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Are you getting spark? Are you getting fuel?
Oct 29, 2007 - 1:58 PM
Yeah it sparks at least. About the fuel part, i'm not sure like the engine cranks and shakes just a little bit and sounds like it will start then it doesn't.
Before this, when it started (after a few attempts) a giant plume of smoke came out the exhaust, and i mean a TON. i don't know if that really has anything to do with this but eh. i might just be forced to tow it somewhere. -------------------- **If you play My Brute, joing the 6gc.net clan!**
Oct 29, 2007 - 2:04 PM
So it turns over, cranks, but never actually fires up?
Oct 29, 2007 - 2:10 PM
Right, and the weird thing is, that never used to happen. All that normally would happen was you would hear the solenoid click when it wouldn't start and you'd just keep turning the key till it started. it never would crank, almost start, and then die. :-/
Oct 29, 2007 - 2:11 PM
Have you checked/replaced the starter relay and the EFI relay?
Oct 29, 2007 - 2:15 PM
No, i haven't. thats where i would check the continuity right?
Oct 29, 2007 - 2:20 PM
correct. Pull them and take them to like AutoZone or something and have them check continuity. Not all of the terminals will have continuity with each other. They are about 30 bucks each. I know schucks (kragen or checkers depending on location) carries both relays.
Edit... nvm.. you said you have spark Can you hear the fuel pump turn on when you turn the car to the "on" position? You won't hear it from inside the car, but if you are in the engine bay and have someone else turn the car on you should hear it. This post has been edited by 95CelicaST: Oct 29, 2007 - 2:24 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Oct 29, 2007 - 2:30 PM
lol the places to get them are foreign to me
but i'll check that here in a minute. i'm going to check continuity of the ignition switch first. i did some more reading of the BGB manual. woop. i have to wait for someone else to get home before i check the fuel pump, but it might be hard to hear since my fans run all the time and i dont know how loud the fuel pump would be. do you know what would cause that plume of smoke to come out of the exhaust upon starting? it only does it if i have to try and start many many times This post has been edited by tonytutino: Oct 29, 2007 - 2:31 PM -------------------- **If you play My Brute, joing the 6gc.net clan!**
Oct 29, 2007 - 2:32 PM
QUOTE do you know what would cause that plume of smoke to come out of the exhaust upon starting? it only does it if i have to try and start many many times Lots and lots of gasoline in the chamber -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Oct 29, 2007 - 2:35 PM
yeah thats what i figured, would that answer your question about the fuel pump coming on? lol
Oct 29, 2007 - 2:39 PM
yep.. pretty much.
check your starter relay. If you have a manual, I would try to push start it and see what happens. This post has been edited by 95CelicaST: Oct 29, 2007 - 2:40 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Oct 29, 2007 - 10:35 PM
not out of gas are you?
Oct 30, 2007 - 2:46 PM
lol no i'm not out of gas. i'm going to go check my relays now... then on to the continuity of the ignition switch. :-/
Oct 30, 2007 - 4:45 PM
bleh, i'm taking it to the mechanic. i can get my power steering back that way too. $$
Oct 30, 2007 - 8:18 PM
Enthusiast ![]() ![]() Joined Dec 24, '06 From jonesville Currently Offline Reputation: 4 (100%) |
check ur crank position sensor and make sure the wires are not torn
Oct 30, 2007 - 10:15 PM
i'm sure if that was a problem it would have thrown a code. but thanks anyways
Nov 2, 2007 - 3:23 PM
got my quote today.... 720 to replace the starter and whole ignition system
ouch. she is turning more into a money pit as the days go on This post has been edited by tonytutino: Nov 2, 2007 - 3:24 PM -------------------- **If you play My Brute, joing the 6gc.net clan!**
Nov 3, 2007 - 9:22 AM
checked the circuit opening relay, green relay behind the radio. with the car ON it should be getting power/ground on 2 of the prongs and have constant power/ground on the other 2.
that relay is what starts the fuel pump and a few other systems. -------------------- |
| Lo-Fi Version | Time is now: September 1st, 2026 - 6:11 PM |
