Oct 28, 2007 - 5:49 PM
Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
after doing some research (and procrastinating) i have figured out that my ignition signal circuit is messed up.
that, however, is something i don't really have much knowledge of. my car wouldnt start on occasion sometimes but i figured it was just a bad starter because eventually it would start after a few tries. But me being the poor kid that i am, i never got around to fixing it. but anyways could someone please explain to me what needs to be done/ checked in detail? -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
tonytutino helpppp car wont start :-/ Oct 28, 2007 - 5:49 PM
tonytutino well i found a working used distributor locally fo... Oct 29, 2007 - 11:48 AM
95CelicaST Are you getting spark? Are you getting fuel? Oct 29, 2007 - 1:42 PM
tonytutino Yeah it sparks at least. About the fuel part, i... Oct 29, 2007 - 1:58 PM
95CelicaST So it turns over, cranks, but never actually fires... Oct 29, 2007 - 2:04 PM
tonytutino Right, and the weird thing is, that never used to ... Oct 29, 2007 - 2:10 PM
95CelicaST Have you checked/replaced the starter relay and th... Oct 29, 2007 - 2:11 PM
tonytutino No, i haven't. thats where i would check the c... Oct 29, 2007 - 2:15 PM
95CelicaST correct. Pull them and take them to like AutoZone ... Oct 29, 2007 - 2:20 PM
tonytutino lol the places to get them are foreign to me
but ... Oct 29, 2007 - 2:30 PM
95CelicaST QUOTEdo you know what would cause that plume of sm... Oct 29, 2007 - 2:32 PM
tonytutino yeah thats what i figured, would that answer your ... Oct 29, 2007 - 2:35 PM
95CelicaST yep.. pretty much.
check your starter relay.
If... Oct 29, 2007 - 2:39 PM
Bitter not out of gas are you? Oct 29, 2007 - 10:35 PM
tonytutino lol no i'm not out of gas. i'm going to go... Oct 30, 2007 - 2:46 PM
tonytutino bleh, i'm taking it to the mechanic. i can get... Oct 30, 2007 - 4:45 PM
Kerr1 check ur crank position sensor and make sure the w... Oct 30, 2007 - 8:18 PM
tonytutino i'm sure if that was a problem it would have t... Oct 30, 2007 - 10:15 PM
tonytutino got my quote today.... 720 to replace the starter ... Nov 2, 2007 - 3:23 PM
Bitter checked the circuit opening relay, green relay beh... Nov 3, 2007 - 9:22 AM
tonytutino well i got my ignition coil, spark plugs, rotor, a... Nov 14, 2007 - 10:14 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 6:35 AM |
