Nov 2, 2007 - 11:41 AM
Enthusiast ![]() Joined Jun 3, '06 Currently Offline Reputation: 0 (0%) |
I was taking out my antenna about a few weeks ago and water was standing in the space beneath it. There is a little hose going from the antenna to the outside of the car that was stopped up but i dont think it would have anything to do with water draining from the car so whats going on? im guessing water is not saposed to be there so do i have a drain clogged up or what? I been under the car looking for a drain and dont see it Ive been looking abot from the mudflap back can anyone help out? kinda sucks i dont want it to rust
Nov 2, 2007 - 1:09 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 4, '07 From US Currently Offline Reputation: 2 (100%) |
yep drain hole is plugged, the hose might have soomething to do with it, i dont remember...
Nov 5, 2007 - 3:54 PM
Bump
I want to get my trunk back together but not sure if water will build up again I see no plug and can feel no plug the hose goes strait to the antenna and out of the car... |
Nov 5, 2007 - 4:22 PM
Enthusiast ![]() ![]() ![]() Joined Oct 28, '07 From epworth uk Currently Offline Reputation: 3 (100%) |
was the hose off your ariel when you stripped panel off as that is wh at and where your water came from first if hose is back on ariel you should be ok
Nov 6, 2007 - 1:46 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
do you have a sunroof? there are two hoses that go from the sunroof to the quarters back there where water that gets in around the sunroof drains to.. supposed to drip out a hole somewhere.
Nov 7, 2007 - 9:47 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
FIX THAT - I have a celica in my drive way with a big ass rust hole where the someone didn't correctly replace the antenna drain. The drain hose is supposed to go into a hole in the frame / unibody (towards the spare tire) that will fix it, and get rid of the water!
-------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Nov 17, 2007 - 10:58 AM
Enthusiast Joined Nov 14, '07 From Jersey, TR Currently Offline Reputation: 0 (0%) |
Or you could just do what i would do. Use a wet/dry vac and suck the living **** right outa that hole. atleast thats wut i would do.
-------------------- One BAD ASS CAR!!!
Nov 18, 2007 - 6:40 PM
I think i got it fixed i tightened the silver thing that screws onto the antenna mast where it meets the quarter panel and i cleaned out the little drain hose. I left half of the fasteners out that hold that trunk plastic in though so i could keep a eye on it from time to time. I really dont think it will leak since i sprayed a water hose right on it but im just paranoid lol
Thanks for all the replies |
| Lo-Fi Version | Time is now: September 19th, 2026 - 6:32 AM |
