Nov 4, 2007 - 5:43 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
I'm looking to replace the spark plug wires as well as my distributor and rotor. I'm going with Toyota for the last two, but was thinking NGK or somewhere along those lines for the wires. Are they any good or is there a better set I can get?
-Matt |
Nov 4, 2007 - 6:29 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Stick with the OEM, their alot cheaper them ngk and are perfectly fine.
-------------------- Member of Team 5sfTe
Nov 4, 2007 - 6:33 PM
Enthusiast ![]() ![]() Joined Apr 29, '03 From socal Currently Offline Reputation: 0 (0%) |
i would go with nology hot wires and ngk spark plugs.
This post has been edited by trdcelica94: Nov 4, 2007 - 6:45 PM |
Nov 4, 2007 - 7:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
oem is far superior to alot of crap out there.
-------------------- ![]() -Rémy 02 SiR, 08 250R |
Nov 4, 2007 - 7:51 PM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
your gonna hear stick with oem from just about everyone so if thats not what you want id go with ngk.
great reliable wires IMO |
Nov 4, 2007 - 7:53 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
i like my nologys
-------------------- ![]() BOOST GETS YOU LAID!!!! |
Nov 4, 2007 - 8:02 PM
OEM wires will fit better, last longer, and perform just as well if not better than 99.9% of the aftermarket wires you can get for the celica
Nov 4, 2007 - 8:28 PM
the oem wires have no problem carrying the voltage of the stock ignition system. unless you're running an aftermarket high power ignition system, the oe wires are more than enough.
Nov 5, 2007 - 10:47 PM
Enthusiast ![]() ![]() Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
my NGKs fell apart.
Nov 6, 2007 - 1:36 AM
Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
NGK, OEM, even TRD (rare) wires are good quality.
| Lo-Fi Version | Time is now: August 29th, 2026 - 5:18 PM |
