> brake fluid and clutch fluid?
post Nov 6, 2007 - 11:37 AM
twitchh17
Joined May 19, '06
From North NJ
where are both of these located? i read in a thread that the brake fluid reservior is located all the way in the corner of the engine bay closest to the steering wheel, then someone said that was the clutch fluid? can someone correct this before i make my way to autozone to get some dot 3 brake fluid? oh and both the clutch and brake fluid take dot 3 brake fluid correct?
post Nov 6, 2007 - 12:07 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
There is no clutch fluid. Theres something for the transmission called "gear oil" specifically for manual transmissions. Unless you have an automatic which needs ATF. automatic transmission fluid. You dont have an automatic and to put gear oil in you will have to get to it by going under the car and the fill plug is on your tranny. You just need brake fluid.
94 Celica gt white (sold)
post Nov 6, 2007 - 12:14 PM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(bccentaur3 @ Nov 6, 2007 - 12:07 PM) [snapback]611732[/snapback]
thank you, good sir
post Nov 6, 2007 - 12:15 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Thank you. Any time.
Lo-Fi Version Time is now: August 27th, 2026 - 7:57 AM
