> Polk subs and kicker amp, wat yall think of this setup?
post Nov 7, 2007 - 1:34 AM
CelicaST_CALI
Joined Feb 28, '07
From Banland
Well i thought id make my own custom box but now im thinking not,what do u guys think of these,there reviews are great,but id need to get a big amp to power them.Concerns,questions,comments?
http://www.crutchfield.com/App/Product/Ite...2122&tp=112
Details:
*ported enclosure with two 12" db Series subwoofers
*3/4" MDF construction with front-panel ABS trim
* polypropylene woofers with Santoprene rubber surrounds
* 2-ohm mono impedance (1 set of heavy-duty binding posts)
* Power Port venting technology
* frequency response: 27-200 Hz
* power handling: 750 watts RMS (1,500 watts peak power)<<<<<<<<<<<
* sensitivity: 103 dB
* 34-1/4"W x 16-1/4"H x 17-1/4"D1 x 13-1/4"D2
* warranty: 1 year
http://www.crutchfield.com/App/Product/Ite...7501&tp=115
# mono subwoofer amplifier
# 375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
# variable low-pass filter (50-200 Hz at 24 dB per octave)
# variable bass boost (0-18 dB at 40 Hz)
# subsonic filter (12 dB at 25 Hz)
# wired remote bass level control
# Class D design
# CEA-2006 compliant
# speaker-level inputs
# preamp outputs
# fuse rating: 40A x 2
# 4-gauge power and ground leads with 80-amp fuse recommended — wiring and hardware not included with amplifier
# 14-11/16"W x 2-5/16"H x 9-5/8"D
# warranty: 2 years
This post has been edited by CelicaST_CALI: Nov 12, 2007 - 10:23 PM
BANNED. for life, you moron.
- CelicaST_CALI   Polk subs and kicker amp   Nov 7, 2007 - 1:34 AM
- - spolski07   sounds like a great sub... heard a lot of good thi...   Nov 7, 2007 - 2:14 AM
- - 94celigts   MTX Cheaper and same quality. Polks are very nice ...   Nov 7, 2007 - 10:17 AM
- - tim86   they look nice... ive also heard great things abou...   Nov 7, 2007 - 11:25 AM
- - CelicaST_CALI   bump   Nov 10, 2007 - 6:09 PM
- - CelicaST_CALI   im thinking of powering them with this,good?: http...   Nov 11, 2007 - 5:29 PM
- - spolski07   QUOTE(CelicaST_CALI @ Nov 11, 2007 - 5...   Nov 11, 2007 - 6:54 PM
- - BLINKYxMUNKEY   I like Polk.   Nov 11, 2007 - 7:48 PM
- - CelicaST_CALI   wow thats cool blinky^^^^^ wat subs and amps are t...   Nov 11, 2007 - 7:57 PM
- - BLINKYxMUNKEY   Two 12in. Polk MM2124 series running off the Polk...   Nov 11, 2007 - 8:54 PM
- - CelicaST_CALI   sounds loud^^^wat do u think of the wiring of polk...   Nov 11, 2007 - 9:49 PM
- - DaCCelica94   i was lookin at the pic of that kenwood amp and th...   Nov 11, 2007 - 10:09 PM
- - BLINKYxMUNKEY   There are no problems with running 2 subs off of o...   Nov 11, 2007 - 10:13 PM
- - DaCCelica94   what i meant was you wont get as much power to bot...   Nov 11, 2007 - 10:17 PM
- - CelicaST_CALI   ya i thought of that,but thats around 600rms per s...   Nov 11, 2007 - 10:27 PM
- - spolski07   if you wire them correctly you will actually get m...   Nov 12, 2007 - 12:58 AM
- - CelicaST_CALI   wat do u mean wire right,just buy high gauge wire?...   Nov 12, 2007 - 1:08 AM
- - CelicaST_CALI   ok well i realized that these subs are 750rms TOGE...   Nov 12, 2007 - 9:29 PM
- - cHinaman727   my friend just got two 1200 w 12's from kenwoo...   Nov 12, 2007 - 10:29 PM
- - CelicaST_CALI   and wat does that have to do with this....that luc...   Nov 12, 2007 - 10:52 PM
- - 97-SX   If you wire 2 2ohm subs in parallel you will get a...   Nov 13, 2007 - 12:40 AM
- - CelicaST_CALI   u got a pm..im pretty sure they are 1ohm a piece.....   Nov 13, 2007 - 12:43 AM
- - 97-SX   They're 2 ohm SVC (single voice coil) Basical...   Nov 13, 2007 - 5:17 AM
- - spolski07   i know the Fosgate P1000-1BD for a fact is 1 ohm s...   Nov 13, 2007 - 11:23 AM
- - CelicaST_CALI   ya BUT on teh specs the read 750 rms TOGETHER,and ...   Nov 13, 2007 - 8:52 PM
- - 97-SX   Fair enough. That sounds like a good plan. I'd...   Nov 14, 2007 - 2:35 AM
- - CelicaST_CALI   ok yes i have read over 50 reviews for this sub an...   Nov 14, 2007 - 7:32 PM
- - Culpable04   off topic but I think is funny how you're all ...   Nov 14, 2007 - 7:53 PM
- - CelicaST_CALI   are u kidding me,200 watts peak power,im looking f...   Nov 14, 2007 - 7:56 PM
- - joehernandez   i have heard lots of good things from polk but im ...   Nov 15, 2007 - 5:03 PM
- - CelicaST_CALI   those look nice   Nov 20, 2007 - 8:28 PM
- - CelicaST_CALI   BUMP   Dec 3, 2007 - 12:31 PM
- - trdproven   I am a no nonsense kind of person when it comes to...   Dec 10, 2007 - 8:52 AM
- - CelicaST_CALI   and how does this have anything to do with this th...   Dec 10, 2007 - 11:00 PM
- - joehernandez   QUOTE(CelicaST_CALI @ Dec 10, 2007 - 11...   Dec 11, 2007 - 2:55 AM
|- - CelicaST_CALI   QUOTE(joehernandez @ Dec 10, 2007 - 11...   Dec 11, 2007 - 8:27 PM
- - tim86   He needs to pick something and see what he likes a...   Dec 11, 2007 - 9:43 AM
- - CelicaST_CALI   BUMP   Dec 15, 2007 - 11:43 PM
- - CelicaST_CALI   anyone....   Dec 17, 2007 - 9:50 AM
- - Culpable04   I have a ZX kicker amp, but mine is 400 watts, the...   Dec 17, 2007 - 10:54 AM
- - CelicaST_CALI   ya i did thanks for the help   Dec 17, 2007 - 9:58 PM
- - itssteve   well i think that you could have gotten a lot more...   Dec 18, 2007 - 12:17 AM
- - CelicaST_CALI   havent bought anything yet   Dec 18, 2007 - 1:02 AM
- - massbrandon   I think those subs sound OK. Personally I think yo...   Dec 23, 2007 - 5:15 PM
- - itssteve   ^^^ i feel the same way, i mean it is only about 6...   Dec 23, 2007 - 6:59 PM
- - CelicaST_CALI   ya but that box is specially made for those subs a...   Dec 24, 2007 - 12:26 AM
- - itssteve   i can almost garenty that the box is not perfect i...   Dec 24, 2007 - 1:22 AM
- - CelicaST_CALI   well over 50 ppl out of 70 that had crappier amps ...   Dec 24, 2007 - 1:35 AM
- - itssteve   QUOTE(CelicaST_CALI @ Dec 24, 2007 - 1...   Dec 26, 2007 - 2:05 AM
Lo-Fi Version Time is now: August 25th, 2026 - 3:55 PM
