> Motor Mounts, Interchangeable?
post Nov 9, 2007 - 1:23 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Are any A series mounts interchangeable? For example, I was looking into some poly mounts, and found some for an AE111, but will those fit right in to my mounts? I'm not talking INSERTS for an AE111, but the entire motor&trans mounts + poly inserts.
**** Photobucket
post Nov 9, 2007 - 2:18 PM
I am not sure, but I would think no. ST205 mounts are different than ST204 mounts, even though they both have S series engines. Most of the mounting is to the transmission.
post Nov 9, 2007 - 2:52 PM
Kadett
Joined Mar 17, '05
From The Netherlands
ST205 mounts are different because of the use of a different subframe, i would assume different car models with the same type or same engine could use different subframe+mounts.
Lo-Fi Version Time is now: May 16th, 2026 - 7:08 AM
