> lowering car, what i need to know
post Aug 14, 2003 - 3:35 PM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
Hi all,
I am considering lowering my car...havent done one so far...
Wanted to know if it benefits in any way other than looks..
Thanks,
Preetham.
post Aug 14, 2003 - 4:14 PM
Assuming you do it right and get springs or good coilovers and replace your stock struts if they're anywhere close to dead, your handling will be better due to a lower center of gravity and stiffer springs. My handling was much better than stock after I installed some KYB GR-2 struts and Eibach Sportline springs. smile.gif
If you get cheap coilovers, your ride will most likely be bouncy, loud, very harsh, and dangerous.
post Sep 3, 2003 - 2:10 PM
Phr0z3n664
Joined Oct 20, '02
From Covington, La
what's better for handling? (ie. The Twistys) Srping or Coilovers, or are they pretty much the same
post Sep 3, 2003 - 7:09 PM
Seth6Gen
Joined Sep 22, '02
From Mammoth CA
springs...
post Sep 3, 2003 - 9:48 PM
BigEdge169
Joined Nov 18, '02
From Texas
I've got a set of Eibach Sportlines on mine and love them. I highly recomend them espcially if you've got bigger wheels, it really finishes off the look.
post Sep 10, 2003 - 8:26 PM
ScoobyDooCruiser
Joined Oct 31, '02
From Boise, ID
QUOTE (Coomer @ Aug 14, 2003 - 1:14 PM)
what did the cost of the shocks and springs cost you?
Did you have to do anything to the kamber?
I'm thinking of lowering my ride too, but I'm a bit of a nooB when it comes to suspension.
psalm 69
post Sep 11, 2003 - 12:37 AM
YellowTwo
Joined Jul 25, '03
From Santa Barbara, CA
all i did was get some $200 intrax 1.8" lowering springs, then i took it to tire pros and they put them on and did all the necessary stuff for $200. some people get a camber kit so the tires dont flare out but i havent noticed anything on mine. 1.8" is probably the lowest ive seen on a celica w/out using coil overs.
post Sep 18, 2003 - 7:26 PM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
can i install springs without coilovers/struts...with a drop of 1.5" and 17"wheels
post Sep 20, 2003 - 2:02 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
sure 1.5 is fine with 17 it should look good.
Team 6gc 2005
Lo-Fi Version Time is now: September 1st, 2026 - 10:58 AM
