> bridged amps !, what would be the ohms ?
post Nov 14, 2007 - 10:03 PM
Culpable04
Joined Apr 17, '06
From New Jersey
as far as I understand when you bridge an amp it acutally reads half of the resistance, right ? so my question is if I have a parallel connection of 2 amps with x ohms each the total resistance ( in the parallel connection ) is X / 2 , so if these subs are then connected to a bridge amp the amp will see half of the total resistance ( x/ 4) ?
post Nov 14, 2007 - 10:06 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
you mean parallel connection of two subs or woofers? but if thats what you meant then yes.... if you have two 8ohm subs (SVC) and they are wired parellel to each other... than total resistance is 4ohms seen by the amp (be aware this method only work for 2 subs.... 3 or more you have to use the full formula....) and if you then bridge this... the amp reads it as being a 2ohm load... but when you are looking at the amps specs... you want BRIDGED 4 OHMS
This post has been edited by pittfirefighter: Nov 14, 2007 - 10:09 PM
Breaking Axles...
post Nov 14, 2007 - 10:07 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(pittfirefighter @ Nov 14, 2007 - 10:06 PM) [snapback]614300[/snapback]
2 subs parallel connected to a bridged amp
post Nov 14, 2007 - 10:09 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
edited... read above
Breaking Axles...
post Nov 14, 2007 - 10:29 PM
Culpable04
Joined Apr 17, '06
From New Jersey
so this amp
Mono subwoofer amplifier
150 watts RMS x 1 at 4 ohms (300 watts x 1 at 2 ohms)
300 watts Peak x 1 at 4 Ohm (600 watts x 1 at 2 Ohms)
is good for these amps ( 2 of them in parallel connection )
Impedance: 8 Ohm
RMS Power Handling: 100 Watts
Peak Power Handling: 200 Watts
I think it should work, but I'm gonna let the experts help me on this
This post has been edited by Culpable04: Nov 14, 2007 - 10:29 PM
post Nov 14, 2007 - 10:34 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
ehhh you're underpowering... you cannot bridge a mono amp... it has to have more than one channel to bridge it... your best bet for sound is to get an amp that puts out 200RMS at 4 ohms to one channel or a 100 watts RMS to each channel x 2 at 8 ohms
Breaking Axles...
post Nov 14, 2007 - 10:40 PM
Culpable04
Joined Apr 17, '06
From New Jersey
but if they are parallel connected they'll be seen as 4 ohms by the amp, and this amp has a 150 watts RMS.
I mean, you may be right, I would just need farther explanation. kindasad.gif
post Nov 15, 2007 - 2:01 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
right but that is then split between both subs... so each only gets 75W's... so you're 1/4 short from what each sub takes...
This post has been edited by pittfirefighter: Nov 15, 2007 - 2:02 AM
Breaking Axles...
Lo-Fi Version Time is now: August 11th, 2026 - 2:14 PM
