Nov 17, 2007 - 9:15 PM
Enthusiast ![]() ![]() ![]() Joined Nov 17, '07 Currently Offline Reputation: 0 (0%) |
What parts are needed for suspension change?
I have Struts and eibach sport's... anything else neede? |
Nov 17, 2007 - 9:41 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
maybe new strut boots and new top mounts since the bearings might be blown. Lots of suspension grease. If sway bar bushings are still good don't bother, but having polyurethane bushings would make a nice upgrade. If you got money get some suspension technique sway bars. Then you're set unless you want the factory gt4 rear strut bar.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Nov 17, 2007 - 10:08 PM
Im talking about needed... a must have... not if you want..
Nov 18, 2007 - 8:08 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
Your question is not clear, we don't know what exactly you are doing hence we can't pin point what you need. Suspension change can vary, you have stated that you have struts and Eibach springs, what else you would need? Maybe sway bars for better rotation and handling?
Nov 18, 2007 - 9:45 AM
like when changing the suspension itself... are there misc items that will be needed...
Nov 18, 2007 - 7:08 PM
any rubber parts needed or something speical... other than the struts, front insirts and springs..
Nov 18, 2007 - 7:35 PM
Well if you put it like that. You need tools, jack stands maybe a lift if you have access to one. You definately need a breaker bar to get those damn bolts off. hmmmm... Oh yes lots of wd40 or pb blaster. O yeah suspension grease and you are set.
Nov 18, 2007 - 7:38 PM
there is a difference between suspension grease and other grease? other than tools and wd40 anything else.... can the old parts from the front suspension be used... like the rubber covers and the top of the spring thing..
![]() is this stuff needed? This post has been edited by Celicam8: Nov 18, 2007 - 9:12 PM |
Nov 19, 2007 - 12:09 AM
If your rubber are broken and such, it would be a good idea to replace them. The bumpstops should be replaced if their jacked up.
Nov 19, 2007 - 12:38 AM
i dunno if they are broken... any way of finding out before?
Nov 19, 2007 - 12:42 AM
ripped, tore up, in pieces?
Nov 19, 2007 - 1:07 AM
ahh i should be good than ^^ thanks
Nov 19, 2007 - 9:09 PM
how the hell you attach the strut to the rest of the init... i cant get both holes even
Nov 20, 2007 - 12:36 AM
guess ya'll cant help me...
| Lo-Fi Version | Time is now: August 26th, 2026 - 10:50 AM |
