Nov 18, 2007 - 7:36 PM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
I need a new Air flow meter. Im being told that a turbo supra has the same AFM as the 3sgte. Is this true? Does anyone have a list of interchangable part #'s for the 2nd generation AFM? I want to be sure I get the correct one. I bought one a few months back(from someone on this sight) and it was definetly NOT the correct one! The part # on that one was convienently scratched off and painted over..
Anyways, any help would be appriciated. Thanks -Brian |
Nov 18, 2007 - 8:37 PM
The part# of the one I have is 22250-74170
Nov 18, 2007 - 8:41 PM
dont get one from a supra or rx7 or some other car. only use one from a 90-93 alltrac/mr2.
whats wrong with the one you have right now? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Nov 19, 2007 - 7:28 PM
QUOTE(lagos @ Nov 18, 2007 - 8:41 PM) [snapback]615442[/snapback] dont get one from a supra or rx7 or some other car. only use one from a 90-93 alltrac/mr2. whats wrong with the one you have right now? In 30* weather I go into low boost mode. It was going into LBM on hot days until I moved the MAF away from my engine bay. I had a maf from a N/A vehical. I tried to switch the temperature sensor with the alltrac MAF I have. I screwed up the circuit board when I tried to solder the connections back together. Its been apart before I had it. These arent made to come apart! Now I know why! This post has been edited by toyotacrazy: Nov 22, 2007 - 6:56 PM |
| Lo-Fi Version | Time is now: August 26th, 2026 - 5:15 AM |
