Nov 20, 2007 - 3:59 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 5, '06 From San Luis AZ Currently Offline Reputation: 4 (100%) |
since one month ago, my car has been like that,
most of the time i drive at 65mph, but the revs were at 2800-3000 depending the weather. but now they go to 2100 at the same speed, is there something bad? am i saving gas!!!!!!!!! -------------------- ![]() |
Nov 20, 2007 - 4:03 PM
you have the o/d on?
Nov 20, 2007 - 4:16 PM
yes it is on, why?
Nov 20, 2007 - 4:44 PM
Enthusiast ![]() Joined Jan 19, '07 From Indianapolis Currently Offline Reputation: 0 (0%) |
It adds an extra gear, so your rpm's would be lower...
Nov 20, 2007 - 4:46 PM
yeah but before my car had 2800-3000 witht the o/d on, thats why im noticing the change on the revs
Nov 21, 2007 - 4:27 AM
bump!
Nov 21, 2007 - 5:28 AM
Enthusiast ![]() ![]() Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
Unless you notice a difference at take- offs then don't complain. That is about the RPM that you should be at for that speed with the OD on. Also it isn't another gear it is just the torque converter in front of the trans locking up. It has a clutch and most of the time it is unlocked and allowed to slip and when you are cruising at a constant speed and not accelerating or decelerating then it is locked.
Nov 21, 2007 - 11:58 AM
QUOTE(bindertch @ Nov 21, 2007 - 5:28 AM) [snapback]616224[/snapback] Unless you notice a difference at take- offs then don't complain. That is about the RPM that you should be at for that speed with the OD on. Also it isn't another gear it is just the torque converter in front of the trans locking up. It has a clutch and most of the time it is unlocked and allowed to slip and when you are cruising at a constant speed and not accelerating or decelerating then it is locked. Well the takeoffs are slower, as if the car was carrying something really heavy, if im on a stop and i press the accelerator all the way down, the car wont throw first gear until its almost hitting the 6500 revs!! and i think that shouldnt happen, -------------------- ![]() |
Nov 21, 2007 - 8:00 PM
6500 rpm at WOT is what i get when my auto shifts up to 2nd from first. i also get about 2100-2200 rpm crusing in 4th with TCC lockup.
OD is 4th gear, the bump after 4th is the Torque converter clutch locking up. -------------------- |
Nov 21, 2007 - 8:28 PM
Enthusiast ![]() Joined Aug 8, '06 From Houston Currently Offline Reputation: 1 (100%) |
I have a manual but I checked on my way home from work and at 2200 rpm in 5th gear I was doing about 55 mph. I dont know how much of a difference between auto and manual it would make on the rpms and speed but thats what I got at 2200 rpm.
Nov 22, 2007 - 2:09 AM
ok,, but does the rpms have something to do with gas?
i mean, like saving it or wasting more? -------------------- ![]() |
Nov 22, 2007 - 2:32 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '06 From Nashville Tennessee Currently Offline Reputation: 5 (100%) |
QUOTE(joehernandez @ Nov 22, 2007 - 1:09 AM) [snapback]616510[/snapback] ok,, but does the rpms have something to do with gas? i mean, like saving it or wasting more? usually the lower the rev the better the gas milage. -------------------- |
Nov 22, 2007 - 2:35 AM
QUOTE(Shocker @ Nov 22, 2007 - 2:32 AM) [snapback]616523[/snapback] QUOTE(joehernandez @ Nov 22, 2007 - 1:09 AM) [snapback]616510[/snapback] ok,, but does the rpms have something to do with gas? i mean, like saving it or wasting more? usually the lower the rev the better the gas milage. really!! today 1/4 of my tank just to travel 55 - 60 miles,, i think its waisting aa looooot! -------------------- ![]() |
Nov 22, 2007 - 2:53 AM
QUOTE(joehernandez @ Nov 22, 2007 - 1:35 AM) [snapback]616526[/snapback] QUOTE(Shocker @ Nov 22, 2007 - 2:32 AM) [snapback]616523[/snapback] QUOTE(joehernandez @ Nov 22, 2007 - 1:09 AM) [snapback]616510[/snapback] ok,, but does the rpms have something to do with gas? i mean, like saving it or wasting more? usually the lower the rev the better the gas milage. really!! today 1/4 of my tank just to travel 55 - 60 miles,, i think its waisting aa looooot! hrm..I dont know then. -------------------- |
Nov 22, 2007 - 10:45 AM
55-60 miles using 1/4 tank for stop and start suburban driving is pretty normal actually. if its constat 65mph highway driving with no stopping then yes its low.
Nov 22, 2007 - 10:54 AM
hmm well 1/4 of a 15-16 gallon fillup would be about 4 gallons, 4 gallons at 20mpg (the poorest I could imagine the 1.8 getting) = 80 miles. You got 55-60, thats like 15 mpg, something is definately wrong IMO. I get upwards of 30-31 mpg with my standard, and I got around 29-30 with my automatic when it was on the road. BTW all on 87 octane.
This post has been edited by roelamizzle: Nov 22, 2007 - 10:55 AM -------------------- |
Nov 22, 2007 - 11:31 AM
i thought the 6g had a 13.2 gallon tank like the corolla has? the most i can ever put in is 10-11 gallons.
Nov 22, 2007 - 12:27 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
QUOTE(bindertch @ Nov 21, 2007 - 4:28 AM) [snapback]616224[/snapback] Also it isn't another gear it is just the torque converter in front of the trans locking up. Incorrect. Overdrive and torque converter lock-up are two separate functions. Overdrive is the 4th gear in our four speed automatic transmission. -------------------- ![]() Project ST204.5 99.88946% complete... |
Nov 22, 2007 - 2:58 PM
QUOTE(roelamizzle @ Nov 22, 2007 - 10:54 AM) [snapback]616567[/snapback] hmm well 1/4 of a 15-16 gallon fillup would be about 4 gallons, 4 gallons at 20mpg (the poorest I could imagine the 1.8 getting) = 80 miles. You got 55-60, thats like 15 mpg, something is definately wrong IMO. I get upwards of 30-31 mpg with my standard, and I got around 29-30 with my automatic when it was on the road. BTW all on 87 octane. yup, thats what im getting concerned right know, now that the gas went up to more than 3 dollars!!! QUOTE(Bitter @ Nov 22, 2007 - 11:31 AM) [snapback]616581[/snapback] i thought the 6g had a 13.2 gallon tank like the corolla has? the most i can ever put in is 10-11 gallons. Celicas have a big tank, its 15.something QUOTE(WannabeGT4 @ Nov 22, 2007 - 12:27 PM) [snapback]616597[/snapback] QUOTE(bindertch @ Nov 21, 2007 - 4:28 AM) [snapback]616224[/snapback] Also it isn't another gear it is just the torque converter in front of the trans locking up. Incorrect. Overdrive and torque converter lock-up are two separate functions. Overdrive is the 4th gear in our four speed automatic transmission. i kind of got confused there, so theres anything that has to be between those two? -------------------- ![]() |
| Lo-Fi Version | Time is now: August 22nd, 2026 - 10:27 AM |
