> CODE 71 EGR Malfunction, Need help
post Nov 28, 2007 - 8:34 PM
mariosdarkworld
Joined Aug 13, '07
From Arizona
Hey guys i just replaced the egr valve now wat cause i spent a lot of money on that S%%T and i cant keep spending money on stuff like that cause its expensive frown.gif can someone help
post Nov 29, 2007 - 2:09 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
QUOTE(mariosdarkworld @ Nov 28, 2007 - 8:34 PM) [snapback]617917[/snapback]
mass airflow sensor? thats a code 71... I think
This post has been edited by nightryder: Nov 29, 2007 - 2:10 PM
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Nov 29, 2007 - 2:27 PM
seafoam the car and also pop the top off of the regulator next to the EGR valve, there is a foam filter it there, it's probably clogged. Replace the filter.
post Nov 29, 2007 - 3:29 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I put up a PDF that has all the codes and descriptions of the errors, along with some ways to fix them... it's from the technical manual.
Here's the link to the page with the codes
Here's the link to the manual itself
And here's the link to the electrical wiring diagrams.
Enjoy!
post Dec 3, 2007 - 6:20 PM
mariosdarkworld
Joined Aug 13, '07
From Arizona
thanks
Lo-Fi Version Time is now: August 29th, 2026 - 6:35 PM
