Nov 29, 2007 - 3:19 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 14, '03 From Jacksonville, FL Currently Offline Reputation: 2 (100%) |
Hey, this is Jen's friend, lOVeYdUbb..
We were doing a compression test on her 5S-FE and we got the compression tester stuck in there. So now there's a hose sticking out of the spark plug well and now we don't know what to do. I've googled and on a Honda forum, it said use penetrating lube a try to remove it. I was wondering if it is safe to use the PB Blaster in the spark plug well or should I just stick to WD-40. If that doesn't work than we have to pull the head and unscrew from there -------------------- |
Jen Compression Tester Stuck Nov 29, 2007 - 3:19 PM
presure2 QUOTE(Jen @ Nov 29, 2007 - 4:19 PM) ... Nov 29, 2007 - 4:45 PM
lagos PB or WD40 should be just fine. If your paranoid, ... Nov 29, 2007 - 5:06 PM
Jen Yeah, PB Blaster isn't working. How long are w... Nov 29, 2007 - 6:48 PM
Jen The hose keeps spinning, but it doesn't come o... Nov 29, 2007 - 7:01 PM
Culpable04 QUOTE(Jen @ Nov 29, 2007 - 7:01 PM) ... Nov 29, 2007 - 7:08 PM
Bitter rip the hose out, jam a big phillips screwdriver i... Nov 29, 2007 - 8:06 PM
Jen BUMP, any more suggestions? Nov 30, 2007 - 12:16 PM
lagos Go buy some really long needle nose pliers from th... Nov 30, 2007 - 12:25 PM
GriffGirl I googled your problem and found someone else on a... Nov 30, 2007 - 12:31 PM
LewFX pull hose off....pull valve cover off...twist off ... Nov 30, 2007 - 12:35 PM
xs94st update? yall get it out alrite? Nov 30, 2007 - 2:39 PM
LewFX hey jen, stay away from your ex peter, he doesnt s... Nov 30, 2007 - 2:43 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 21st, 2026 - 3:23 AM |
