Dec 4, 2007 - 12:41 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
Hey guys, I was thinking about finally getting a 4 chan amp for the component speakers but I'm just a little concerned about the celicas electrical system. My headlights already dim a little bit from the mono amp and having a huge cap isnt helping either, but will the electrical system hold up if i added another amp? Im really not looking forward to having to replace the alt or having any other problems... any suggestions would be great
Dec 4, 2007 - 1:18 PM
Enthusiast ![]() Joined Jun 3, '06 Currently Offline Reputation: 0 (0%) |
how is your ground wire? Make sure it is as big as your power cable if not bigger and is grounded as close to the amp as possible.
Dec 4, 2007 - 7:33 PM
yea its same 4 gauge right next to the amp, but I would just be getting a small alpine 4 channel such as the alpine mrp-f250... also correct me if im wrong but since the amp has a crossover then I would be able to tune the speakers a lot better and have them sounding a bit more clear
This post has been edited by tim86: Dec 4, 2007 - 7:36 PM |
Dec 11, 2007 - 8:27 PM
Enthusiast ![]() ![]() ![]() Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) |
Easiest solution is to add a 2nd battery! Had the same problem with my friends car. He had 2 jl audio mono amps and it was sucking a LOT of power, even with a capacitor. And when it came time for him to add mids & Heights amp, I just added a 2nd battery for him to ease the stress!
Dec 11, 2007 - 10:48 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
before adding a second battery and therefore more stress on your alt, i think you should get a YellowTop they are AMAZING batteries. i have one and my lights don't dim AT ALL. but when i got the battery i replaced all my ground wire from the battery to the chassis and the engine. im sure the 8ga to 2ga jump helped a lot to..
Dec 16, 2007 - 11:42 PM
Enthusiast ![]() Joined Dec 14, '07 From yorktown Va. Currently Offline Reputation: 1 (100%) |
ok well lets start at the begining i wouldnt waste my money on a yellow top the are very over rated, i would go to walmart and buy the 1000cca everstart maxx batt for the front, i know that the batt will hold fine with about 100-110 amps or so when you are at idle or driving, and if you want to get another batt i would go get a marine g31, i say this because i am pulling 2500 watts off the stock system with these batts and when i am driving the voltage is never lower than 13 but at just idle will fall to 12.2 or mb a lil higher, or i would try to get a kenetik batt because they put out really good power. also i would look into redoing all of the ground wires under the hood as that really helps the voltage, i know i had about a .4 voltage incress over all after doing this. also if there is anything over 12-1500 watts of total power i would look into 1/0ga wire 4ga just wont cut it at these levels sorry if i rambled or missed anything
This post has been edited by itssteve: Dec 17, 2007 - 2:13 AM |
| Lo-Fi Version | Time is now: August 9th, 2026 - 10:04 AM |
