> fuel pump
post Dec 6, 2007 - 10:14 PM
pabel89
Joined Sep 28, '07
From new jersey
i was wondering can i install the walbro fuel pump and my fuel regulator before installing my turbo cuz i wanna go get my fuel line done at this place then the other stuff i can do it my self i just want to kno if i can get it done and its ok i can drive with it back home with out the engine getting damage or anything and does anyone kno where can i get an oil return line for my turbo?
post Dec 6, 2007 - 11:14 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
What injectors will you be using?
post Dec 6, 2007 - 11:18 PM
pabel89
Joined Sep 28, '07
From new jersey
the one u said the mazda mx-6 turbo injectors.
post Dec 6, 2007 - 11:23 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
It's better if you leave it stock for now. If you don't install an EMS, the car will run too rich, even with the regulator at its lowest pressure. Fuel economy will be horrible, and that's not a good idea when gas prices are sky-high.
post Dec 7, 2007 - 6:48 AM
pabel89
Joined Sep 28, '07
From new jersey
yea i kno im not planning to start the project now im prob starting in january but im trying to gather up as much info so when the day comes i can do everything right. can i still install the walbro fuel pump in my car and the FPR with out having my turbo on it?
post Dec 8, 2007 - 2:45 PM
pabel89
Joined Sep 28, '07
From new jersey
does anyone kno if i can install the walbro fuel pump and the fuel prssure regulator before installing the turbo??
post Dec 8, 2007 - 7:36 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
I just told you to leave it stock. Didn't you read my reply? Here it is again:
What is your hurry anyway? The fuel pump install takes about 30 minutes if you do it slow, and the regulator about an hour if you change your fuel lines to braided lines. Do you understand this?
You can knock them out the same day you install everything else. Why install them now? It'll only slow your car down and make it waste gas.
post Dec 8, 2007 - 9:14 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(pabel89 @ Dec 8, 2007 - 11:45 AM) [snapback]620935[/snapback]
yes you can install it, and the car will run. BUT you will have terrible fuel econmy and you might kill your catalatic converter from runing so rich.
post Dec 9, 2007 - 12:47 AM
pabel89
Joined Sep 28, '07
From new jersey
ok thanxs for the info.
Lo-Fi Version Time is now: May 18th, 2026 - 3:01 AM
