Dec 8, 2007 - 9:33 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 12, '06 From Fresno CA Currently Offline Reputation: 1 (100%) |
hey guys im having a problem with rpm ideling,when i leave it in neutral the car wants to die untile i give it gas.when i give it full throle is take about 2 seconds for response(in gear). i just change my spark plugs,distibutor cap and rotor and fuel filter. if it helps.thanks in advance.
pandakid car trouble Dec 8, 2007 - 9:33 PM
pandakid anyone? Dec 15, 2007 - 8:44 PM
Celicam8 vaccume? Dec 15, 2007 - 9:06 PM
jcbass7 make sure you didn't split or accidently knock... Dec 16, 2007 - 4:50 PM
pandakid well my check engine light came on.i got a scaned ... Dec 20, 2007 - 9:36 PM
thespacepanda Misfiring could be bad seals, bad wires, plugs, ba... Dec 20, 2007 - 10:00 PM
Havok1997GT QUOTE(thespacepanda @ Dec 20, 2007 - 10... Dec 20, 2007 - 10:17 PM
lagos are you sure you installed the plug wires in the c... Dec 21, 2007 - 2:28 AM
pandakid well i just changed my PCV valved and hose from th... Dec 21, 2007 - 5:51 PM
thespacepanda If you're getting sludge in the pcv make sure ... Dec 21, 2007 - 5:58 PM
pandakid i replaced my spark plug wires and unbolted the ba... Dec 23, 2007 - 10:22 PM
Bitter well whats the code? Dec 23, 2007 - 10:24 PM
pandakid P0300,p0301,p0303.i think theres more but the scan... Dec 23, 2007 - 10:46 PM
Bitter random misfire, misfire 1, misfire 3.
get a cheap... Dec 24, 2007 - 12:25 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 2:31 PM |
