> camshafts
post Dec 9, 2007 - 8:52 PM
JasonX
Joined Oct 18, '07
From Orange County, CA
is there anything wrong with using camshafts from a 5th gen to re-grind by coltcams to use on a 6th gen. (both engines 5sfe). Would there be any problems?
Thank you
Replies (1 - 2)
post Dec 9, 2007 - 9:27 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
probably not
post Dec 10, 2007 - 12:09 AM
yes and no.
the 90-91 5th gens (GTs) have different (smaller lobes, less agressive) camshafts than the 92-99 GTs. I would suggest you use the same size cams as the ones in your car. Use any from a 92-99 GT and you should have no problems with a regrind.
Lo-Fi Version Time is now: August 24th, 2026 - 7:09 PM
