Dec 10, 2007 - 5:06 PM
Enthusiast ![]() ![]() Joined Mar 20, '07 From Bradenton,FL Currently Offline Reputation: 4 (100%) |
When i drove my car today i heard the exhaust pop and now my rpms surge up and down. it acts like its going to shut off but it doesnt. it just drops down to 200 or 300 rpms and shoots back to 1000rpms.
PLEASE HELP!!!!!!!!!!!! |
Dec 10, 2007 - 5:39 PM
Maybe check all your vacuum lines and make sure you didn't blow a hose, and also check your manifold to make sure you don't have a hole or a crack in it. It sounds to me like you have an airflow issue. But I'm no mechanic, and a lot of people on here know way more than I do about this kinda stuff. That's just where I'd start though.
Dec 10, 2007 - 6:12 PM
Enthusiast ![]() ![]() Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) |
go to an exhaust shop and get ur exhaust pipe weld prob has crack or have a hole in it.
Dec 10, 2007 - 7:01 PM
QUOTE(pabel89 @ Dec 10, 2007 - 11:12 PM) [snapback]621497[/snapback] go to an exhaust shop and get ur exhaust pipe weld prob has crack or have a hole in it. would that cause the rpm surge? |
Dec 10, 2007 - 7:07 PM
QUOTE(purepunishment @ Dec 10, 2007 - 4:01 PM) [snapback]621515[/snapback] QUOTE(pabel89 @ Dec 10, 2007 - 11:12 PM) [snapback]621497[/snapback] go to an exhaust shop and get ur exhaust pipe weld prob has crack or have a hole in it. would that cause the rpm surge? Yeah -------------------- ![]() |
Dec 10, 2007 - 7:16 PM
![]() Enthusiast ![]() ![]() ![]() Joined Nov 23, '07 From Houston TX Currently Offline Reputation: 0 (0%) |
Is there a check engine light on?
Dec 10, 2007 - 7:49 PM
no check engine light.
Dec 10, 2007 - 11:50 PM
QUOTE(purepunishment @ Dec 10, 2007 - 7:49 PM) [snapback]621528[/snapback] no check engine light. if your having surges of RPMs it has something to do with the Air Flow or exhaust But a Pop could concern me. Get under the car and go all the way down the Pipe see if you can find any holes, after that, follow it up to the Manifold see if you have an holes there, though i would think that if its that high you'd hear it leaking. after that and still nothing check the Intake system and see there but i would start from the @$$ of the car and head up. |
Dec 11, 2007 - 5:20 PM
check your IAC valve, and the hose running to it.
its the middle, larger hose of the 3 running to the underside of the throttlebody. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: August 25th, 2026 - 1:04 AM |
