> Help: Lack of heat
post Dec 11, 2007 - 2:49 PM
azian_advanced
Joined Apr 18, '05
From Calgary
hey guys.. i'm trying to figure out why i don't get much heat from the heater. i'd say i'm getting half the heat than what i should be getting.
i recently replaced my thermostat and radiator cap and flushed my radiator fluid and have no leaks whatsoever inside or out.
when i warm up the car, the upper radiator hose gets hot and the lower one is sort of warm (like it should).
but the heater hoses are barely warm. i've bled the system for any air locks also. my guess is there is a clog somewhere along the heater core lines or perhaps the heater core is defective/corroded. i really hope it isn't cuz it costs $400 or more from the dealer.
what do you think the problem might be? any help would be greatly appreciated.
Replies (1 - 10)
post Dec 11, 2007 - 3:21 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
QUOTE(azian_advanced @ Dec 11, 2007 - 2:49 PM) [snapback]621786[/snapback]
my guess is the heater core.
post Dec 11, 2007 - 4:39 PM
azian_advanced
Joined Apr 18, '05
From Calgary
ok.. i just finished working on it.
i was able to squeeze my hand to where the coolant hose for the heater is located (the hose between the coolant neck from the block to the heater coolant valve). i squeezed the hose and felt like something was in it, it felt like slush/ice. so i removed that hose and drained the fluid and noticed some dirt particles that remained inside. you see, that hose is like a U shape and the bottom of the U shape is where dirt was getting collected.. this is not a good sign for the heater core and lines. now after filling up with coolant and rebleeding the lines all over again, the heater lines are now heating up like they should. yay! tongue.gif
right now, i'm getting sufficient heat. so i'm happy. and i don't think the heater core is that bad considering the heat i'm getting now.
Case Closed
post Dec 11, 2007 - 8:54 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
remove both heater core lines and flush water through it (like with a garden hose) backwards from the normal flow, then replace those old heater hoses. that should bring your heat right back.
post Dec 11, 2007 - 9:01 PM
purplegt4
Joined Feb 7, '03
nice. good to know it worked out.
post Dec 12, 2007 - 1:46 AM
azian_advanced
Joined Apr 18, '05
From Calgary
thanks Bitter.. i should of thought of that.. it's gonna be pretty tight getting that 2nd heater line out. i'm guessing my heater core is clogged in some areas with dirt because it takes a while to get heat even after my car has already warmed up.
i'll try this out tomorrow
post Dec 12, 2007 - 8:49 AM
azian_advanced
Joined Apr 18, '05
From Calgary
i'm so dumb... there's no way i can do this because it's freezing here and my garden hose is frozen. i'll have to wait til summer frown.gif
post Dec 12, 2007 - 11:40 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
That's so crappy... is the spigot or line to it frozen? If not, bring the garden hose in the house for a day! Thaw that bitch out! smile.gif
post Dec 12, 2007 - 12:35 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i'm sure the faucet outside will be frozen too. i will wait for this spring to flush it out. thanks for the replies.
post Dec 12, 2007 - 5:22 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
QUOTE(azian_advanced @ Dec 12, 2007 - 5:35 PM) [snapback]622107[/snapback]
You could just get a really long hose and attach it to the faucet inside...
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Dec 12, 2007 - 10:49 PM
azian_advanced
Joined Apr 18, '05
From Calgary
meh.. i don't think it's worth all that trouble besides, i don't have the same type of faucet outside inside.
anyway, right now, for the most part, my heat is back and feels as hot as it should be. the only problem is it takes a little longer before i feel it.. i've already but a radiator shield i custom made myself (out of cardboard and tape tongue.gif) and it seemed to help a bit in this freezing weather.. plus i have the warmth of heated seat, remote starter/alarm and an interior electric heater and block heater wired together for quick warm ups. smile.gif
Lo-Fi Version Time is now: August 12th, 2026 - 1:06 AM
