Dec 21, 2007 - 6:51 PM
Enthusiast ![]() Joined Dec 9, '07 From PhiLLy Currently Offline Reputation: 0 (0%) |
I was driving normally when I was in first gear about to switch to 2nd gear the motor started to knock.
There's no check engine light and when the car is at idle it seems like it wants to turn off. I also checked the oil and it was fine still a light brown color. Piston, oil pump, new engine (hopefully not) If anyone can give me a slightly better idea as to what it might be I'd appreciate it. Thanks! This post has been edited by PHLCELICA: Dec 21, 2007 - 9:07 PM -------------------- Celica *The Baby Supra*
Dec 21, 2007 - 6:58 PM
![]() Enthusiast ![]() ![]() ![]() Joined Nov 23, '07 From Houston TX Currently Offline Reputation: 0 (0%) |
dude, Knocking means dead engine. Means you have thrown a rode or bent a valve, could be a lot of things but they all lead to one thing. New Engine.
Dec 21, 2007 - 9:33 PM
if its knocking, ask Who's there?
I suggest you find a used engine and swap it yourself. you prolly find one used cheap. then, the one you have now, rebuild, make it stronger add stuff, then in a year or so put it back and then turbo it. or take this one to the shop and have it rebuild.. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Dec 22, 2007 - 12:08 AM
check your spark plug wires. 1 bad wire can cause some bad noises.
Dec 22, 2007 - 12:40 AM
It knocks pretty hard so I'm almost sure it's not a spark plug wire.
Now if it comes to a full engine swap this is what I'm looking at. http://cgi.ebay.com/ebaymotors/90-93-JDM-T...sspagenameZWDVW Is the swap doable? -------------------- Celica *The Baby Supra*
Dec 22, 2007 - 10:25 PM
Well I needed a new motor but it might be better than i thought......
My mechanic is gonna throw in a used 1MZ-FE V6 motor -------------------- Celica *The Baby Supra*
| Lo-Fi Version | Time is now: September 1st, 2026 - 12:33 AM |
