> 3mzfe
post Dec 22, 2007 - 5:50 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
I was wondering if the 3mzfe v6 will bolt up to a awd trany. just curious . biggrin.gif
[img=http://img56.imageshack.us/my.php?image=signature2fs0.jpg]
post Dec 23, 2007 - 3:49 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
post Dec 23, 2007 - 4:28 PM
Kadett
Joined Mar 17, '05
From The Netherlands
I believe there's an 5th gen All Trac who swapped a 3.x Liter engine in it. Dont know if it was a 3mzfe or 1mzfe.
post Dec 24, 2007 - 1:28 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
it was a 3vz. he used the st185 tranny with the 2004 RAV4 transfer case.. had to grind and cut to get it on though
post Dec 24, 2007 - 9:41 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
thats weird. why use the rav4 transfer case. why not the stock all track transfer case. thanks for the helpful info smile.gif
post Dec 24, 2007 - 11:16 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
the stock transfer case would protrude into the block by about 10mm. too much to grind away from either one.
post Dec 29, 2007 - 2:17 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
post Jan 1, 2008 - 6:14 PM
GMan
Joined Jan 17, '04
From Boston, MA
> JDcelica
> '94 GT Coupe
> From Rochester, NY
Not a stock AT tranny.
CelicaTech > Fabrication & Aesthetics > Custom Engineering/Design/Fabrication V6 Alltrac writeup.
http://www.celicatech.com/forums/showthread.php?t=20037
All the info is there. Successfully done in the UK.
One other project is ongoing in the US.
There is a FWD 5th gen Celica in CA that is up and running...
(1 or 2 fwd 6th gen v6 ? )
Auto tranny and V6 awd out a Sienna, Highlander ?
Regards;
post Jan 3, 2008 - 6:44 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
Thanks GMan for the link. It has some very useful information on it. Does any one know the easyer way to make a 6gc awd so I could attempt a v6 awd celi. The only why I can think of is to make a costum brakit to hold all of the components. thanks smile.gif
post Jan 4, 2008 - 1:16 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(JDcelica @ Jan 3, 2008 - 11:44 PM) [snapback]627913[/snapback]
2004+ Toyota Sienna.
post Jan 4, 2008 - 6:35 PM
JDcelica
Joined Jan 11, '07
From Rochester, NY
QUOTE(Kwanza26 @ Jan 4, 2008 - 6:16 AM) [snapback]628005[/snapback]
? I don't understand
Lo-Fi Version Time is now: September 12th, 2026 - 4:45 AM
