Jan 3, 2008 - 12:53 AM
Enthusiast ![]() ![]() ![]() Joined Nov 17, '07 Currently Offline Reputation: 0 (0%) |
I am looking around and planning my to buy my 4age or 4agze and I was wondering if rebuild kits are worth it
1.6L 90/91 Corolla GTS 4AGE 16 valve DOHC Fuel Inj. $327.06 EKTO30LM Major Engine Kit: contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable), and a set of expansion plugs (does not contain camshaft, timing kit or oil pump). Pistons & Rings: Std., .020, .040. Bearings: Std., 10, 20, 30. $401.48 EKTO30LG Gold Engine Kit: (Major kit as above) with oil pump $228.89 EKTO30LR Re-Ring Kit: contains complete gasket set, main bearings, rod bearings, thrust washers (if applicable) and a ring set. Rings: Std., .020, .040. - I'm not exactly sure where I'd get these parts and at what cost... Also, will the 4age kit work on a 4agze, only difference is supercharger... I cant see that being a problem, but worth asking |
Jan 3, 2008 - 2:43 AM
Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
Get registered and post a thread on Club4ag. This way it's more guaranteed that you'll get the feedback you want since it is a website based on the 4age engine. And alot of the members there majority have the some type of experience when coming to rebuilds and so forth.
Jan 3, 2008 - 3:22 AM
ok, I tried registering and the email w/ pass doesn't go through... *crap*
Jan 4, 2008 - 1:13 AM
The question of whether a rebuild kit is worth it is something only you can answer for yourself and would depend entirely on what you want out of a motor. If you're asking for an opinion, well, without considering the additional cost and time of rebuilding, it's always a good thing to do, but if time/money is a concern, look over the motor and decide what is and isn't necessary in terms of rebuilding/refreshing.
Anyway, there are slight differences between the several different 4AGE motors, mainly the size of the crank and rods during the different production phases. The kits you list (90-91 Corolla) will have different pistons from all other 4AGE models as well as the 4AGZE. The 4AGZE will have different pistons also, but the main/rod bearings will be the same between all models 88+. The older models prior to 88 will have different crank mains and rod journals. Other differences are in the piston design, which coincide with the crank/rod update, which utilize a full float piston pin as opposed to the older press fit pin. -------------------- "It's ok to be naked girl... I'm an artist!"
Jan 4, 2008 - 2:08 AM
Well I'm looking for the newer SilverTop 20V from the 92 or 95 corolla, and something with 30-40k miles on it so that it doesnt necesserly need a rebuild...
Jan 5, 2008 - 2:47 PM
not a bad idea to pull the valve cover and drop the oil pan to give it a good look over before installing it.
Jan 5, 2008 - 3:42 PM
I was talking to Dr.Tweak, he recommended changing the seals... and just cleaning it up... which I will do...
| Lo-Fi Version | Time is now: September 12th, 2026 - 5:22 AM |
